worn flywheel causing starter problems?
Car: 89 Camaro rs
Engine: 2.8 v6
Transmission: manual
Axle/Gears: rear wheel drive
Hey all had a starter problem for quite a while in my 89 2.8 camaro. For a while it wouldn't hot start and I had to wait for a runs an hour for it to cool down or whatever so it would start. The I replaced the starter with a remanufacturd starter that started up fine every time but had a high pitched squealing every time I started it. I used all the shims that came with it and the noise wouldn't go away, and now that starter sounds even worse when I start it. My question is would a worn flywheel have any effect on the starting capabilities of the starter motor or is the pinion gear on the remanufacterd one just really worn out? Thanks much.
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: worn flywheel causing starter problems?
Did you actually measure the starter to flywheel or just throw the shims in because they were supplied? Dis-connect negative battery cable and remove cables from starter. Remove screws holding solenoid to starter and remove. Remove your trans dust shield. Engage the starter drive by pulling the armature back. The armature is that big cylindrical hunk of steel that slipped out of the solenoid when you removed it. Check your starter gear engagement to the flywheel. With the teeth lined up, you shouldn't have more than 0.030 clearance between the top of the tooth and the bottom of the valley between the flywheel teeth. Shim accordingly. While your down there, have someone rotate the engine a full turn so you can check the flywheel for damaged teeth. HTH!
Car: 89 Camaro rs
Engine: 2.8 v6
I tested the starter with all three in succession adding one every time and it didn't go away, then I did half shims like the "instructions"suggested on both sides and still nothing changed... I didn't measure it but that would be a smart idea. Thanks much.
A standard paperclip is .035. Bend it straight, you should be able to fit the wire
between the teeth of the flywheel and the starter gear.
most times shims should not be needed, take them all off and check the clearance.
if you need less clearance shim the outside bolt only..
Ghettobird52
12-29-2023 08:23 AM
db057
08-11-2015 10:11 PM
