White smoke
Old 09-22-2015, 08:21 PM
KCG
KCG's Avatar
Car: 89 IROC
White smoke
Need some advice. I went and looked at a bone stock 87 IROC 305/At car today. After about 2-3 minutes of idling, it starts to spew very light color, almost white smoke. The engine sounds fine and I pulled the dipstick before starting and the oil looks good.
Is this water related? Blown head gasket or cracked block?
I didn't pop the radiator cap before hand.
If anything, the exhaust pipes are oily looking. The owner said someone told him a modulator valve could be bad on the trans sucking oil in to the motor.
Any ideas?
Old 09-22-2015, 09:03 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Re: White smoke
BEWARE! But yes trans fluid can leak past the 'modulator' valve on the trans, and trans oil when sucked into the engine will burn white. Check the Trans fluid level vs. coolant levels. The lower level should give you a clue... BTW, if trans oil was burning in the cylinders everything should be looking nice and clean in there after removing the cylinder heads?
Old 09-23-2015, 05:42 AM
KCG
KCG's Avatar
Car: 89 IROC
Re: White smoke
Would you happen to know where that vacuum connection is on the engine?
Old 09-23-2015, 09:05 AM
Car: 1986 IROC Z-28
Re: White smoke
It'll probably be on the passenger side, towards the bottom of the carb...
Linson
09-25-2021 07:55 PM
Pac J
05-17-2020 10:44 AM
FormulasOnly
07-23-2018 08:47 AM
PAFORM350
Wheels and Tires
10-02-2015 07:21 PM
Badass355ciz28
09-28-2015 08:31 PM
Quick Reply: White smoke
