slightly built 327 HP estimate.
Numbers don't mean too much but I'm curious what sort of power level this is capable of.
-4 bolt 3970010 block .40 over
-forged 327 crank
-forged rods
-L2256F speed pro pistons
-supposedly 10.4:1 CR
-Edelbrock rpm heads 180 cc runners
-comp 286h cam
-Edelbrock performer intake
-Dan Davinci holley 750. At least it has holley metering blocks and bowls
-1 3/4 hedman shorties
-3 inch exhaust back to y pipe or open dump
-underdrive pulleys
-also has a 150 wet plate system but I haven't tried it yet.
Any idea what this would make at the crank? Its going through a built 700r4 and ford 9 inch with 4.20s
-forged 327 crank
-forged rods
-comp 286h cam
-underdrive pulleys
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: slightly built 327 HP estimate.
providing you dial in your Carb properly. Unknown heads? 350 - 370HP @ the crank.
your diff will most certainly hold- up. Won't take long to take out your 700
you will need a 2800 stall minimum. your gear ratio is covered.
It's Edelbrock rpm heads. 700r4 has an extra clutch pack and a bunch of other things from what previous owner said. Also has 3500 stall converter
Juds89RS
10-27-2015 01:45 AM
