Exhaust to quiet....
Old Oct 23, 2015 | 12:45 PM
1fast91's Avatar
I bought a 91 formula with a dynomax exhaust system(not exactly sure which muffler it has) on it and it's really quiet when I take off. I hear the engine more than the exhaust even from outside the car. It sounds great inside the car and at idle. Until I can redo the whole exhaust system, any suggestions on how to make it louder without spending a ton of cash on it?
Old Oct 23, 2015 | 04:50 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Re: Exhaust to quiet....
To hear the DynoMax Super Turbo, keep your hatch open a bit.. Try a 4 inch foam block between the hatch and latch and tie the hatch closed in the open position.. Now go for a ride,, You'll hear it...
Old Oct 23, 2015 | 05:04 PM
1fast91's Avatar
I hear it just fine in the car. I had someone else drive it away from me and as I stood there as he drove away it's really quiet, u can barely hear it take off down the road.
Old Oct 23, 2015 | 09:31 PM
Nothing the matter with that, depending on the muffler, maybe the internal glass mat just needs to be broken in a bit???
Old Oct 24, 2015 | 01:07 AM
Night rider327's Avatar
Car: 1988 Camaro
Take muffler off and put a torch to the inside of muffler to burn up the steel wool packing.
Remove the cat(s) and install a cat delete pipe in it's place.
Put cone/bell shaped large dia. tips on it. We use to call them bellow tubes
If you are local to GA. I have a couple of full cat back systems for sale that will be louder... Edelbrock SDT system and a flowmaster system. $200 each
Old Oct 24, 2015 | 06:03 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
You can just buy a new muffler. That shouldn't break the bank. If your looking for something you can hear inside the car. Look into a flowmaster 80 series muffler.
Old Oct 25, 2015 | 04:28 AM
Stroopwafel's Avatar
Car: 88 Camaro
Engine: 305 LO3 TBI
Axle/Gears: Stock
Just get your muffler off.
Drive around for a few miles and see if it is what you like.
If you like it, get some exhaust pipes so your exhaust wont end underneath your car.
I did it, and it sounds awesome.
Old Oct 25, 2015 | 12:35 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Lmao
Old Oct 26, 2015 | 07:43 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Ive got a 3in Flowmaster setup and its pretty loud but not annoying. I heard a 3rd gen recently with a "Texas Speed Rumbler" which is designed for a 4th gen but works perfectly on our cars. It was LOUD! Sounded great! I will one day go with one of those if I buy another 3rd gen.
Old Oct 27, 2015 | 09:12 AM
1fast91's Avatar
When I can get the $$ I was thinking of putting on a chambered exhaust and eliminating the cat-s. Possibly doing headers too.
I was just looking to see if I can get this muffler louder but I don't think that's going to be the case...until I can redo the system.
I had a flowmaster exhaust once before and I liked the sound but I see a lot of people prefer the chambered exhaust, not sure which direction to go to.
Old Oct 27, 2015 | 02:31 PM
Car: 1988 Camaro
Flowmaster is a type of chambered exhaust. When it comes to mufflers you have 2 common types... Packed or chambered. Packed ones uses a steel, or stainless steel wool type packing inside them.
Chambered uses sheet metal to make baffles/chambers inside the muffler
Old Oct 30, 2015 | 03:17 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Don't worry about making noise just for the sake of noise.
no green
Mar 3, 2016 05:19 PM
okfoz
Oct 13, 2015 02:19 PM
InfernalVortex
Oct 3, 2015 07:40 PM
83ho87gn
Sep 26, 2015 08:49 PM
83ho87gn
Sep 24, 2015 08:58 AM
