ACC Fuse blown linked to "Computer Command Control" yet ECM works?
I am currently diagnosing why Accessory fuse is blowing but checking my manual indicates there are two "Computer Command Control" fuses.
One is part of the ACC 20amp and a seperate 15amp fuse for a "Computer Command Control".
now with the fuse blown/removed, while all the stuff linked to it (Horn, Interior Lights, door/mirror/hatch switches) don't work, there appears to be NO effect on the running of the car.
Isn't the "Computer Command Control" the fuse for the ECM? I would think it would stop the car from working or change the running of it at the very least? Yet has a separate 15amp fuse for it as well (which is not blown)..
Confused..
ALSO, "Radio Clock" is linked to the 20amp ACC fuse yet radio on my stock cd radio still works?
1992 Camaro Z28
Confused..
1992 Camaro Z28
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: ACC Fuse blown linked to "Computer Command Control" yet ECM works?
What often causes the ACCY fuse to blow is the socket part of the lighter. Don't know why, but they seem to short out eventually even if you don't use it. Happened to mine. Take the bezel off around the gauges and unplug the connector on the back of the lighter, but careful where you put it, the orange wire going to it is always hot. Try replacing the fuse and see if everything goes back on. If that works then either replace the lighter socket or whatever you want to do with the space.
HTH, Henry
HTH, Henry
What I cannot understand is what does the 20amp fuse do with the "Computer Command Control" because I took out the burned fuse and the car runs fine so does my radio clock. Yet there is a seperate fuse for the Computer COmmand Control as well..
On Probation
That actually is not what I asked.
While I appreciate everyone taking the time out to reply. Somehow everyone who did, misunderstood what I was actually asking. :-)
[QUESTION #1] : What I am asking is what exactly does the "ACC" part connect to as far as the "Computer Command Control" goes?
The reason I ask this is because the 20amp "ACC" fuse is blown (I pulled the fuse out for now) and while all the rest of the circuit "Horn, Switches (Side mirrors, door, hatch) do NOT work (rightfully so since they are part of the "ACC" fuse circuit), there appears to be nothing wrong with the running of the car.
I would THINK that the car would not even start if the computer is not connected. I would think the "Computer Command Control" would be the ECM is it not?
But then it makes no sense because there is a separate fuse "15amp" JUST for the "Computer Command Control" as well.
[QUESTION #2] : The other question is, how come the CD radio (factory) clock WORKS fine, even tho it indicates "Radio Clock" as part of the ACC fuse circuit?
Thank you very much
Thank you very much
Car: 1983 Trans Am
Axle/Gears: Stock
Check the orange wire off the battery, it has a fusible link on it. My car ran too
with the fuse pulled out. I cut the link out and replaced it with a fuse.
Car: check
Engine: check
Transmission: check
Thank you very much
Thank you very much
The radio battery power is from the ARC fuse (20 A), not the ACC fuse.
...but checking my manual indicates there are two "Computer Command Control" fuses.
RBob.
