cam help please
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
cam help please
first off thanks any one who helps i have decided to pretty much pull my car off the street except for the occasional car show and what not im building a new complete drive train for the car this winter and need some help choosing a cam for my car it will be using a roller style cam hears some info on what i have already
car is 3000lbs rear gear and stall will be changed to match cam and power band
th350 trans with brake
28 inch tires
2peice rear main 4 bolt main 350 bored 60 over
motown 220 cast iron heads ported and port matched to intake 2.08 and 1.6 valves
brodix hvh hv1 intake
5.7 rods with flat top forged pistons
pbm 70000 383 cast crank for 350 main and 5.7 rods
single stage plate shot of nitrous 150 shot
28 inch tires
Re: cam help please
i think nobody wants to give an opinion because the next guy will of course say, "no, thats not what you want." LMAO!
I didnt see a mention of F.I. or carb. IS this going to be a dedicated drag race or pro-street type build? How high do you want to push the RPM's?
I'm thinking your looking at a nitrous cam with lots of duration and lift, going by the information provided and the brake. probably somewhere around a 290 on up duration?
OK,...the ice has been broken.
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
Re: cam help please
thanks both for your reply's yes this will be a 99% track raced drag car from now on beside the occasional once or twice a year drive across town for a show it will be carb not fi im still deciding if im gonna run alcohol or race gas race gas is allot easier to get in my area then alcohol with the heads and intake im using i would say i would need to pull around 7.5 to 8 thousand rpm to use there power im not sure if i should use sold roller or hydrolic roller i whould think solid with that high of rpm what do you think this will be my first roller build always used flat tappit before this but tired of loosing on the big end
Re: cam help please
You are better off solid. But you can get a hydraulic that high but you need short travel morel lifters, big pushrod, shaft rocker for precise geometry and pretty stout springs with titanium retainer. Cam lobe has to be relatively milder to for top end stability
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
Re: cam help please
ok so it definitely sounds like ill be going solid roller just for ease of mind then
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
Received 1,672 Likes
Re: cam help please
Right... what bracket, dial-in, goal, whatever... wouldn't hurt to tell us how long a track you plan to run as well.
Those pesky details.
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
Re: cam help please
ill be running 1/4 i hope to at least be in the tens with the bottle my machine shop thinks i can get med to low 9 on bottle but u know you can hope in one hand lol
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
Re: cam help please
yeah eventually im gonna add two more stages of nitrous but i think im gonna need a better crank before i start throwing that at it
