pleas your thoughts will the mods work for me
I have a 1988 tpi 305 with a 130,000 miles 700r4 trans. The car runs great I'm looking to make a lil more power ..I'm looking for input an or to see if some one has made the mods I'm thinking about ..(will it help me or hurt me on power) an will it work ...
Im looking to put a lt1 cam +change valve springs to support the lift ..Run 22lb injectors ..(will I need different ECM chip for enjectors)..have already changed to a 373 rear end and looking to use a torque converter from a Astro van or s10 v6 ...Please ur thoughts
Things I have dun or have purchased to do
New excel bistridutor ,cap an roder
New enjectors 22lb
Ported the plentum ports to machMach exsexact size of the air runners.
Nmad 8.5 msd wires
373 pozy
Long tone headers
New enjectors 22lb
Nmad 8.5 msd wires
373 pozy
Long tone headers
Re: pleas your thoughts will the mods work for me
What country are you living in? Performance parts can be hard to find outside the US so that might limit you a bit.
I'm in the us.indiana what makes u ask that ?...Is it something in the setting saying that I live out of country
Thanks for the input ....So it is passable to do those upgrades ..Will the tune just upgrade the ECM or will I half to change the chip
1 Post
Car: 91 Firebird
You're not going to want to use the old style hei distributor, just use the stock one. If you really want get a new coil for the stock one. You need a computer controlled distributor. Otherwise your car will not run right even with a new tune. I'm not even sure the in cap coils dizzies will fit on a tpi.
Lol no just short text spelling ..an phone puts what it wonts with the check spelling on sometimes
Actually I'm not from here just living here I'm from Texas so maybe just maybe we spell an use the the English language there a lil different to ..Or mabey it's just fast texting and or just typing it out as it comes to you .. Seeing is how y'all under stood it I reckon it's not to bad
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Lt1 cam is a waste. Get a non oem cam. Unless you want to waste time and money for minimal gains when you could do an easier cheaper modification and get more out of it.
Cool thanks have any ideas on specks for one that will work for stock heads plan on having them ported an polished ..
Sorry for the misspelling on the post between me and this phone ..Words sometimes have not enough letter s or too many letters hope it is fixed now
I would not put any more money into stock heads besides some new springs. Save for something better and aftermarket.
Lol it's fine ....I didn't no how bad it was until I read it ..It's my phone it also trys to change words when you hit space bar ..Anyway ..I was also wondering about a ls1 set up like the wiring harness an ECM could that bolt to my transmission I have access to a good one for 200 bucks ECM everything ..I just wanted to keep the tpi it makes the car look original
I'm sorry lt1 ...I have went over every thing in my head an I think it would bolt right up but u no how it is when u swapping thing that wasn't designed to be there ..
1 Post
Car: 91 Firebird
Not too many things with cars is easy. Technically it will bolt in, but rewiring and all the other crap and changes to make it run are a little different. It will bolt up to his trans and that was his question. Personally, I'd just do whatever I feel comfortable with, and that wouldn't be switching to an LT1. I hate wiring cars, I can do it, I've done it, but it's soooo damn tedious.
