Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
My Modified IROC vs My 2013 370Z Touring
Old 04-22-2013, 03:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The IROC is equipped with a 5.7 V8 in front of a T-5. The rear ratio is a limited slip 3.23. 330 HP @ 5000, 380 ft. lbs of torque @ 3800.
The 370Z is equipped with a 3.7 V6 in front of a 7-speedo auto (and paddle shifters). The rear ratio is a limited slip 3.40. 332 HP @ 7000, 270 ft. lbs of torque @ 5200.
Both vehicles are in the 3200-3300 pound vicinity.
Which car would likely be the winner at quarter mile's end?
Top end would also be interesting. The 370Z is electronically limited to 155. My guess is that the IROC would be in that ballpark.
JamesC
Old 04-22-2013, 03:29 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: My Modified IROC vs My 2013 370Z Touring
Only one way to know for sure, James. Let's take them to the track. I'll drive your IROC.
Old 04-22-2013, 05:58 PM
JamesC's Avatar
Sorry, Chazman, I only let really cool people drive my cars.
JamesC
Old 04-22-2013, 09:20 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
JamesC
BURN!!!
If you can launch the IROC pretty well you should get the early lead. But the 7 speed and the higher rpms of the 370 may eventually run you down.
Old 04-22-2013, 09:51 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
The favor is looking good for the 370z. It has a little better gears but also with the 2 extra gears it will have a lower gear for lauching. If you put better gears in the Iroc with the torque maybe but also which one is lighter?
Old 04-24-2013, 06:22 AM
Street Lethal's Avatar
The Iroc-Z will more than likely be the winner at the end of the 1/4 mile, just from looking at the data alone it will have a much better rate of acceleration...
Old 04-24-2013, 08:18 AM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
they are roughly the same weight,same power but the iroc has 100+ ft-lbs I say the camaro smokes it
Posted from Thirdgen.org App for Android
Old 04-24-2013, 11:31 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
IROC wins all day if it actually makes that power and you can shift/launch!
Old 04-26-2013, 07:10 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Similar power, weight and gears so it should be close.
Whether the IROC wins or not, it will sound much better trying. But I would advise against doing this at all unless you have an extra T5 ready to go.
Old 04-26-2013, 09:13 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
The Iroc will destroy it off the line with the torque but the 370 has really different tranny ratios the rear gear isnt all of it cause I bet it goes through gears just as fast as the Iroc just with a way higher rpm redline. It has tighter gears for the 7 gears cause you probably have the same overdrivejust 7 gears coming to it for tighter gears
Old 04-26-2013, 09:55 AM
JamesC's Avatar
Here's what I've found.
From Nissan:
13.3 @ 105.7
From CarCraft and ProSim Drag Simulator (the weight was a bit more and the gears a bit steeper behind a TH350):
12.98 @ 104
BTW, the exhaust note on the 370Z is pretty darned cool, though maybe not as wicked as the IROC at WOT.
JamesC
Old 04-26-2013, 06:36 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Why dont we just race them?
370 is going to win tho.
Old 05-03-2013, 02:03 PM
Axle/Gears: 2.77
did you race?
Frozer!!!
01-19-2024 04:55 PM
Ducati900ss
09-02-2015 09:05 AM
Linson
08-31-2015 04:52 PM
Camarothatcould
08-20-2015 08:49 AM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: My Modified IROC vs My 2013 370Z Touring
