BANNED TOPICS... once again, EVERYONE READ
#51
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: BANNED TOPICS... once again, EVERYONE READ
Q1: My buddy has a 305TPI and recently replaced plugs and wires. After sitting for hours it starts but sputters and sometimes just stalls but only when cold or sitting for a long time, enough to bring it back down below 50*. What could be the problem. I'm thinking fuel filter.
#52
1 Post
I re-read the post so I'm changing the response. This doesn't belong here, it's not a simple Q with a definitive A. Ask this in the General Tech section. The previous post should be moved and mine should be deleted.
#53
Car: 1989 GTA
Engine: 5.7L
Can somebody give me or point me in the right direction.
Looking for the Delco part #'s
1989 5.7L GTA
plugs
wire
cap
rotor
oil filter
fuel filter
thanks
mike
1989 5.7L GTA
plugs
wire
cap
rotor
oil filter
fuel filter
thanks
mike
#54
1 Post
http://198.208.187.182/internet/Vehicle.jsp
Enter any vehicle and you can look up the part number on any part you want.
#55
Car: 88' Iroc-z
Transmission: T-5 WC
Axle/Gears: 3.73 9-bolt
O.k. so I have a 88' IROC-Z with a stock 305. The rear has a set of 3.73 gears. I wanted to squeeze a bit more power outta my TPI and am looking at getting some Edelbrock Shorty headers, a flowmaster exhaust system, SLP intake runners and a 52mm Throttle body.
You mention about a also going with a cam and intake, who makes a intake manifold that can be used with my stock heads? Th eedelbrock one suggests the vortec ones but are they able to bolt dirrectly on? Also what a good mild cam.
I'm looking at mayeb bumping up the horsepower to around 300 if possible. Any other suggestions? Thanks
#56
Do you know how many bits is a nibble?
Very good point.
8 bits (11111111) = 255
The reason GM didn't assign an additional byte was simply because the code would have to check if the first byte was on before referencing the second byte. That would be. Messy..
If your a coder you'll understand this.
A 10 or 16bit ECM would be the solution for this issue with MAF.
-- Joe
-- Joe
#57
I HAVE 91 Z28 CONVERTIBLE W/L98,
Q: WHAT CAUSES THE OIL TO BACK UP THE DIPSTICK LINE AND PUSH THE DIPSTICK OUT AND CAUSE IT BLOW ALOT OF OIL ON TO HEADERS ETC. ALSO WHEN I GET ON IT FROM A DEAD STAND, SHE RUNS THRU 1ST AND 2ND FINE BUT 3RD OR 4TH MAY TRIGGER SOME TYPE OF FUEL SHUT OFF OR IGNITION, EITHER WAY SHE LOSES ALL POWER.
BRIEFLY: I RECENTLY DID THE INTAKE GASKET. BEFORE THIS I HAD NO PROBLEMS WHAT SO EVER WITH ACCEL AND TOP-END. BUT AFTER I HAVE HAD THE OIL PROBLEM AND THE LOST OF HIGHEND POWER.
ANY SUGGESTIONS
ANY SUGGESTIONS
#58
ANY SUGGESTIONS
ANY SUGGESTIONS
#59
OK AND WHAT ABOUT THE THE FUEL OR JUST PLAIN CUT-OFF POINT I GET TO IN 3RD AND 4TH WHEN UNDER FULL THROTTLE, IT JUST LETS GO AND AS THE ENGINE RPMS DROP IF I TOUCH THE GAS AGAIN THE POWER IS RIGHT BACK THERE, THE ENGINE NEVER ACTUALLY CUTS OFF JUST SOME TYPE OF LOST OF POWER, OR IS IT TIMING?
AN THOUGHTS?
AN THOUGHTS?
#61
yeah if i floor it, and hold it it shuts out like i said but if i back off for just a second then get back on it gradually up to top end, it never shuts out
#62
#64
Car: 1986 K10 Suburban
Engine: 5.7 TPI Speed Density
Is it also taboo to post questions regarding TPI conversions into non thridgen vehicles, as long as its in the TPI section?
#66
Q:What about Holley Stealth Ram (HSR) Hood Clearance?
A:It will fit under Camaro hoods w/o any probloms and for a firebird hood you must cut away the bracing above the throttle body such as shown in this thread
https://www.thirdgen.org/techbb2/sho...hood+clearance
This thread also has information on the fuel lines needed.
The HSR will not fit corvette hoods--check out grumpyvette's latest posts as he is working to get a custom plenum made to fit corvettes and firebirds without the clearance work.
#67
Car: 1989 Camaro IROC-Z
Engine: L98 350 (5.7)
Transmission: 700R4 Automatic
#68
Car: 1988 Camaro Sport Coupe convertible
Engine: 350 tpi with cam
I know this has to be a stupid question...but I can not figure out how to start a thread, to ask my own questions....I am using my phone, because its more convenient, but still.. If someone could help me out here...I would really appreciate it. Thanks
#69
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Tmic87,
I like the hood and would like to know if you purchased it and where I may be able to get one.
#70
Car: 1991 camaro z28
Engine: 5.7
Transmission: 400
Axle/Gears: 700
dont touch
this was 2015 after a tune up on the 91 z28 5.7 this thread is old I started screwing around with the timing at the distributor and ended getting a timing light had no used one in years.had to scotch brite the harmonic balancer to see the makers. that tells me nobody touched it for a long time got stop by the police for a unintended burnout ended about 8' after a week of trials .iban
#71
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
I like how I go to reference this thread for a specific subject, and it just throws me to search.
In the future, at least directly link to posts pertaining to the 'banned' questions. It'd help a lot instead of making me wade though 10+ years of data.
#72
A number of years ago there was a couple of threads where a bunch of our guys were fussing with a bunch of Camaro owners from Australia, and they were bragging etc. BUT the guys down under claimed fantastic MPG…after much talk and figuring things out it was discovered that there was a Easter egg they called a “Lean Burn Cruise” setting and theirs was turned on and ours was not.
So once we got them turned on the USA Cars also got great MPG something like 30/35MPG.
I have run search after search and cannot find these old threads.
Is there a special section for OLD threads??
Can you help me???
Thanks.
Rich
Can you help me???
Thanks.
Rich
#73
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
whats all needed to install HSR can i use stock throttle body and stocke fuel rails?? is there a forum outlining this ive been searching for hours
#74
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
This is a sticky thread? Dumb policy.
T.L. (07-15-2023)
#75
Car: '91 Firebird Formula
Engine: SP383 Deluxe FIRST® TPI Intake
Transmission: Tremec T56
Axle/Gears: Moser 9" Eaton Truetrac Motive 3.89
Q: Which intake is the best Mini ram, Accel intake, or super ram.
A: Buy them all then do your own testing. Then let us know.
edit: Also, do some searching. Over the years a few members HAVE posted comparisons between the intakes. 2 names that come to mind are Mike Davis and grumpyvette (probably mispelled) But noone is just going to repost their findings cuz some newbie is asking, just search it out and you'll learn more.
onebadta
12-02-2002 01:31 PM
Jim85IROC
05-22-2002 01:05 PM
