Questions about stock 350 heads.
What is the casting number for the stock 350 heads, isn't 882?
Does anyone have flow numbers on this?
Would a stock 350 head make a good performance upgrade for a 305, provided its milled down to 58cc of cource.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Rob
'86 TA 305 TPI
Edelbrock T.E.S.
The stock 350 L98 f-body iron head is 14101083, its 64cc combustion chamber, and no its not worth putting on a 305. I would suggest some 305 specific heads, or just port match your stock heads and save up for a 350 engine.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you mill down the Head, Your intake will more than likely not sit right on your block.
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
Hotchiss strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
87 Formula TPI (5 Speed) Yellow/Gray STOCK
83 Camaro (Parts)
83 T/A (parts)
www.3rdgenformula.com
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
NinjaNife
08-23-2015 11:49 AM
