Roller Rocker Arms and HP Gains?
Old 01-29-2008, 12:59 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
I did a search on this topic and did not find an answer to this question except for a stock engine.
I have a 5.0 liter TPI engine with a Comp Cam cam, headers, etc. The cam raises gross valve lift to about .480" on both the intake and exhaust. I currently have stock 1.50 rocker arms. If I went to 1.50 full roller rockers would I gain much HP. Comp Cam advised that I can not to 1.60 due to the pressed in studs and problems with springs.
Old 01-29-2008, 01:04 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: Roller Rocker Arms and HP Gains?
About a 5 HP gain.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd see almost no HP increase.
Old 01-29-2008, 01:37 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
get a good set of 1.6rr's, new springs and a shim kit. then u should see some gains.
Old 01-29-2008, 03:29 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
With 1.6 rockers you may have to open up the push rod holes in the heads to avoid clearance problems. You might consider using 1.6 on the intake side and 1.5 on the exhaust, because the higher exhaust lift doesn't really make a difference.
Old 01-29-2008, 05:12 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
On another chat board I attend they dyno there cars every year. In the past year a guy had installed roller rockers and something else. It netted him nothing. However, you should beable to rev the engine a bit faster.
Old 01-30-2008, 01:11 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Thank you everyone for your input. A consensus has emerged that this would provide negligible to no HP increases.
Old 01-30-2008, 06:10 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
So let me see, I beg to differ, You go from stock 1.5's to 1.6 roller rockers, and your not gonna see any difference? You are gaining lift, plus taking away friction, How are you not going to gain anything? If you have .480 lift with a 1.5 rocker, you are going to have .512 lift with a 1.6 plus it is a roller rocker, hm that should be enough to see some gain right?
Oh, I see, you guys are just comparing a stamped 1.5 rocker to a 1.5 roller rocker? If that's the case, you wouldnt gain much, but you are decreasing friction, and the parts will last longer, and yes maybe rev a little higher a little faster.
Old 01-30-2008, 06:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
the only way i can see power gains is if a high rpm motor is experiencing alittle valve float with heavier steel (even tho stock stamped isnt heavy) rocker and goes to a lightweight aluminum rocker arm which enables the springs to control inertia better.
Full roller thing i dont think you'll see much, maybe a few ponies at HIGH rpms but its not worth the upgrade. Just alittle easier on parts i guess.
Hotrodboba400
12-10-2019 07:07 PM
TX-SleeperC5
02-24-2016 01:34 PM
New2Chevy
09-28-2015 12:35 AM
ericjon262
09-11-2015 06:07 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Roller Rocker Arms and HP Gains?
