Idle help
Old 06-23-2011, 07:41 PM
87bucketgta's Avatar
Car: 87 GTA
Engine: 5.7
Transmission: auto
Idle help
Hey guys, I need some help/advice. I just got my throttle body back I had it sent off and rebuilt and bored to 52mm. My car always had a crazy kinda idle. I went ahead and also installed a new IAC while I was there. I followed the reset pro. and set the tps. And also set the timing. The problem I seem to be having now is car seems to Idle fine only thing is when Im setting base idle is says get it to about 450rpm, well I cant get it that low about 600 is as low as i can get it and it still runs. When I plug everything back in car idles really nice around 600-700 when I put it in gear it will die out almost everytime if I tap the gas and its fine till and will stay running. I go back to park and try to go to reverse or drive same thing again. Any advice!!! Thanks in advance
Grant2k
04-04-2016 08:21 AM
86IROC112
11-27-2015 09:54 AM
junior419
09-22-2015 03:19 PM
Stroopwafel
09-11-2015 06:38 AM
IROCtometal
09-09-2015 10:01 AM
Quick Reply: Idle help
