intake plenum
Old 07-15-2013, 11:48 AM
89 formula TPI's Avatar
intake plenum
hey guys,
i recently removed all the bolts on my intake plenum and runners to get to my EGR not realizing a few were different sizes!
does anyone have a layout of which size bolts go where? (assuming longer ones bolt runners to the manifold and shorter bolt the plenum to the runners but not sure which holes require a longer or shorter bolt)
thanks in advance!
Old 07-15-2013, 12:13 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: intake plenum
Pictured above is the typical set up for a 1986-89 MAF based system. Speed density is similar. (A) Intake manifold. (B) EGR valve (C) EGR temp switch (maf only) (D) PCV fitting, to the left is orifice for cold start injector (maf only) (E) Thermostat housing neck and bolts (F) Bolts needed for top plenum and runners- 13- M8x1.25x30mm, 2- M8x1.25x40mm, 4- M8x1.25x50mm, 1- M8x1.25x30mm throttle bracket stud, 20 total, these use a T40 Torx head bit, NOTE these are metric. (G) Fuel rail typical for a "F" body, maf system, fuel lines for Corvette is on opposite side. Look at picture, as this is a complete system (H) cold start injector and fuel tube (maf only) (J) Fuel injectors-8 total (K) Intake runners, speed density will not have the cold start opening (L). (M) Intake air sensor (P) Intake plenum, with throttle body, be sure to get complete throttle body with no missing upper and lower cover plates, bottom plate has provisions for IAC and coolant tubes. (Q) Throttle bracket and bolts (R) Vacuum fittings for fuel regulator, heater control and brake booster, speed density will have a fitting for MAP sensor and mounting boss.[/QUOTE]
Old 07-16-2013, 09:53 AM
Re: intake plenum
TY! the diagrams are very helpful and i see that the bolts include:
13- M8x1.25x30mm,
2- M8x1.25x40mm,
4- M8x1.25x50mm,
however i am still not sure which length bolts should go where. e.g. where do i put the two 40mm ones and the four 50mm? assuming base of the runners but not sure which holes!
Old 07-16-2013, 10:08 AM
Engine: Lb9
Transmission: M20
Re: intake plenum
IIRC the 2 50mm go through from the backside of the intake into the runners the picture above with the intake shown and the red lines . 40mm goes in the runner bottom side holes. because the only other longer ones are for the throttlebody but I think those are 65mm.
Old 07-16-2013, 01:51 PM
Re: intake plenum
i see thank you, i will get out there and correct this!
thanks all!
Old 02-01-2017, 01:14 PM
duece's Avatar
Car: 1990 Iroc Z convertible
Re: intake plenum
I received my 89 iroc tpi unit in pieces can someone please show where each lower intake runner bolt goes......there are different sizes...thanks
Old 02-01-2017, 01:49 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: intake plenum
see above photos
Old 02-01-2017, 03:22 PM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Axle/Gears: Hawks 8.8 - 3.73
Re: intake plenum
On more than one occasion I've held the runner in my hands and just placed the bolts in to see how far they stick out the other side, then moved them around as necessary. .....I'm pretty good at it now though, sheesh......pulled em off TOO many times!!!!!
Old 02-01-2017, 06:26 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: intake plenum
TunedPerformance had the (2x)40s and (4x)50s reversed...
40mm (middle length) are the inside-out bolts. These are the only ones that screw into the runners. These are indicated by the red lines in post #2, middle picture.
50mm (long) - one for each runner pair. Between the tubes into the lower manifold.
30mm thread with stud - This is driver's side, middle, upper bolt. If you have everything, there is a plastic sleeve with a clip-arm to hold the cables for throttle, cruise, and possibly trans.
30mm bolts everywhere else.
And Abubuca x2... stick the bolts through the runner holes and figure out which goes where.
Old 02-02-2017, 11:32 AM
duece's Avatar
Re: intake plenum
Thanks......I have one bolt that is a different length than the rest about a 1/4 inch longer than the 30mm...a little shorter than the "inside out" bolts...I guess I can shim it with washers for now...
Old 02-03-2017, 11:02 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: intake plenum
x2 this helps
Nice diagram man brings back memories I hated working on those lol.
Old 02-04-2017, 08:31 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
Re: intake plenum
I coulda used this info when I did my job....ended up grinding one down a smidge...kinda like the three stooges putting a puzzle together..they would just cut pieces to fit!...
Bubbajones_ya
09-14-2015 08:38 PM
Nick McCardle
09-10-2015 08:36 PM
toronto formula
09-10-2015 07:31 AM
e3pres
09-09-2015 01:51 PM
Quick Reply: intake plenum
