Ported Plenum and Runners
1 Post
Car: 1989 Formula Firebird
Transmission: 5-speed
Axle/Gears: 3:45
I have an 89 Formula LB9 5-speed car and want to port the plenum and runners. The car has 1.6 roller rockers, holley fuel pressure regulator, air foil, K&N filter and dual cats. Should I get a 52mm throttle body to go along with the porting or keep the stock 48mm? Also fuel gauge is stuck passed full after they put the regulator in, could it be a short somewhere? Thanks!
jonarotz
10-16-2015 09:51 PM
snowflake
10-06-2015 06:47 PM
