LB9 TPI 081 Head Porting
Hello
I have some questions about porting my 1989 305 TPI 081 Heads.:
Is it worth to unshroud the stock 1.84 intake valve (Lift 0,488) ?
I added a picture of a chamber with the locations of interest
Can i remove the material at area b completely (is there enough wall th.) ?
1 Post
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
Re: LB9 TPI 081 Head Porting
There are some gains to be had for sure, but compared to a more modern head design (of the many that are available)just know you are essetially polishing a turd here. Takes a lot of work and the gains will be minimal. However if you want a maximized stock style powerband and are not looking for much HP maybe 10~20 max - go for it. The car can still run good/better by spending the time.
Look for headbytes porting on Youtube for pointers..
Yes i have. I removed material in the with the arrow marked areas. But now i have the problem of a damaged piston and scratched zylinder wall. Now i have to rebuild the engine. What a s...
