Unusually high oil pressure
Old 05-02-2016, 09:49 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
My oil pressure gauge on my 91 GTA is right to the max and maybe a little more. Im not sure if the gauge is broken....if a sensor is to blame or if its something more serious.. any help would be aprreciated. I just bought this car and it was sitting at a dealership for at least 5 months.
Old 05-02-2016, 10:20 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Unusually high oil pressure
Similar problem in this thread. I just glanced through it quick, but it sounds like a wire might be disconnected from the sensor.
https://www.thirdgen.org/forums/tech...auge-pegs.html
Old 05-02-2016, 10:46 PM
Engine: V8 305
thanks i will take a look
Old 05-04-2016, 10:37 AM
racerx520's Avatar
could be a bad sensor too. my sensor went and said i had no oil pressure.....replaced it with a brand new napa sensor and it showed it pinned all the time. replaced again and it was fine.
Old 05-04-2016, 09:53 PM
Engine: V8 305
i bought this. http://www.ebay.ca/itm/111961785878?...%3AMEBIDX%3AIT
hopefully it fixes the problem.
Old 05-08-2016, 05:22 AM
armos's Avatar
Anytime there's a concern about oil pressure, it's best to verify it with a mechanical gauge. The electric senders aren't that trustworthy, they're just useful for drawing your attention to a possible issue. If you're worried, hook up a mechanical gauge to get a real reading.
edit: although in this case, if the needle is fully pegged then it's most likely an open circuit. The replacement sender you bought will probably fix it.
It's good that you bought an ACDelco. I went through 4 knockoff senders (I think they were BWD brand) on a V6 which kept being replaced under the lifetime warranty - all of them were unacceptably inaccurate at the lower end of the scale. The original GM and 2 Delco senders I've used were all much more accurate in comparison to a mechanical gauge.
Old 05-09-2016, 09:19 PM
Engine: V8 305
yeah i like to stick with ac delco when going with a stock replacement. then u know for sure.
1MeanZ
Members Firebirds
02-17-2017 02:32 PM
jharrison5
06-11-2016 10:11 AM
racerx520
04-13-2016 09:54 AM
85@IRocZ
04-08-2016 02:41 PM
RedLeader289
South East Region
04-07-2016 06:55 AM
Quick Reply: Unusually high oil pressure
