Cold Starting issues
Car: 1988 GTA Trans AM
Transmission: 5 speed
Looking for some help, 88 GTA 305TPI is having problems starting when cold, takes 3 to 4 cranks to get started
Just replaced the temp sensor and same problem
9th injector was removed, installed chip into adapter that has smog and cold start removed from tune
no codes, cant find my damn usb to obd1 cable i just bought, wanted to check temp sensor before replacing it but replaced it anyways
i have searched and dont know what to do next, thanks in advance
Jeff
Jeff
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Cold Starting issues
I've been battling the same thing. No resolve still after swapping the entire fuel and ignition system.
Subbed as hopefully someone will have some ideas.
I am still having the issue starting when cold, what I do not understand is that in the winter I go out to garage and start the car and it fires first crank, really quickly, and its darn cold out, now its 70 out and damn thing wont start right
on another side I have located my OBDI cable, is there something I can look at, is there a guide that explains what stock values should be for various sensors?
as always, many thanks
Where did you get your first chip? I bought mine from TPIparts.com and it made the car run terribly. I put on a 9th injector block off plate, new injectors, new gaskets, rebuilt fpr, and it still took so many tries to even get it to hold an idle.
I'm now pulling the engine out because I got tired of wasting money on the 305 when I've wanted to put a 383 in it since day one.
The chip adapter I purchased was from tpiparts.net
should I look for a 89 chip instead of the adapter? is it to do with the removal of the 9th injector? but it has this problem when the air temp is 70-75 but in winter when i start it in garage it is 10-30 out it starts no issue
BG1959
07-20-2016 02:22 PM
Procharged GTA
Exterior Parts Wanted
03-26-2016 01:56 PM
