Kinda a backwards tranny question..
Old 02-14-2005, 02:07 PM
DigitalMonarch0's Avatar
Car: 25th Anniversary RS
Engine: 305 TBI
Axle/Gears: Stock 2.73s for now..
I know that this question has been posed in many ways many many times... I just want to be sure that I am understanding everything that I have read correctly before I get going on this.
I am swapping an older 700r4 (with a rebuild kit installed) into my car which now currently has a 700r4 from 1992. Therefore I have an electronic speedo. Can I pull the "VSS" (which i'm assuming stands for Variable Speed Sensor) out of my current tranny when I start the swap and install it into the older one?
I appologize for asking this as I know it has been talked about many times, but I have done my searching and I am still confused.
Old 02-15-2005, 06:38 AM
Engine: 305 TBI
ttt...
No one can give me an answer on this?
Old 02-15-2005, 07:19 AM
ede
ede's Avatar
giving you an answer isn't the hard part, giving you a correct answer would be
Old 02-15-2005, 07:53 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
YES. Swap it out. Be sure to check the color of the speedometer gear on the output shaft. It should be the same as the gear on the 92 trans. If not swap them too.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
HoosierinWA
10-07-2015 10:15 AM
bjpotter
10-04-2015 07:48 PM
92projectcamaro
09-29-2015 07:07 PM
1HotZ28&SS
09-28-2015 08:58 PM
Quick Reply: Kinda a backwards tranny question..
