My T56 Swap Thread....
Old 10-15-2013, 11:59 AM
  #601
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: My T56 Swap Thread....
If you are dead set on a T10 transmission you should make a new thread. The information contained in this thread should be specific to the T56 swap itself. It will reduce confusion for when people are actually looking for T56 specific information.
Old 10-20-2013, 09:22 AM
  #602
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Anyone ever find out what that shim was for under the FW? on page 1?
Have a PN on it or the GM LT1 throwout bearing?\
Did the LT1 T56 cars come witth pilot bushings or bearings. PN?
Having some issues with my conversion clutch doesnt seem to be disengaging quiite enough synchros arent happy. Trans guy mentioned something about a shim...was wondering about the one on P1
Also the PP bolts are long discontinued, use Mc Cleod 1502
As sofa said NO other bolts, youll regret it.
Also on the CF fw dont worry about weight is way overrated.
Old 10-20-2013, 09:53 AM
  #603
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
TOB comes attached to the pressure plate.
I'm sure they all came with pilot bushings but i would and did use a bearing.
I'm not sure about that shim but I don't think it has anything to do with the clutch engagement/disengagement. If this was a push clutch rather then pull then yes you could use TOB shims to adjust your engagement 'too much shim and it won't disengage all the way'.
True that on the bolts!!!
As far as "dont worry about weight is way overrated", i couldn't disagree more. If you couldn't feel the difference then i would say it is way overrated BUT, the difference is SOO obvious and of course it depends on how much power your trying to push through it. If your not pushing some real horsepower then stick with a heavy flywheel.
Old 10-20-2013, 02:14 PM
  #604
jmd
jmd's Avatar
Car: `86 SS / `87 SS
To maintain total flywheel height when turning one.
10085246 is one number.
Your total height (Valeo style LT1 T56 clutch) is very unlikely to be too short in causing the isuse, so that shim wouldn't be needed. The pull clutches end up being too tall, causing an issue. If anything, surfacing the mounting surface of the flywheel could help achieve a shorter height.
Old 10-24-2013, 08:47 AM
  #605
Axle/Gears: 4.11
youre right I worded that wrong too tall could be it
Tried putting a Sachs and this Centerforce side by side but that apparently means nothing its once they are torqued down that decides where the T/O bearing sits. The CF clutch fingers dont angle down much the Sachs/stock stuff does.
Gonna put it all together and take a closer look at whats doing what how far it takes the slave rod to actually disengage go from there. Its always been "Ok" but never "quite right". A nicely working setup should shift like butter all the time
Old 10-30-2013, 07:07 PM
  #606
irocdis's Avatar
Anyone find a good solution to Mechanical speedo issue? I'm trying to mate a T-56 to an 88 iroc L98. Speedo is only mechanical.
I have 2 solutions..but they are both expensive.
http://www.abbott-tach.com/cablex.htm
OR CHECK THIS OUT!!!!! ANYONE EVER USE THIS BEFORE?
http://www.swfabrication.com/product...products_id=28
Maybe its cheaper and better to use aftermarket T-56 Magnum with full size bell housing that already comes with mechanical and electronic speedo provisioning?
Old 10-30-2013, 07:26 PM
  #607
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Contact Alloy on here who does the tailshaft conversion. $325 I think, works great. Had it done to mine, no clunky/noisy converter box and a lot cheaper than what SW Fab is charging for same thing.
Allioys website: www.t56cablespeedometer.com
Old 10-30-2013, 07:47 PM
  #608
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Alloy = best option
Old 10-30-2013, 08:40 PM
  #609
Axle/Gears: 4.11
Gotta agree here Gm quit doing this for a reason.
Spoken to enough clutch co's, even D and D agreed.
None of them arewihtout release issues the hydraulics suck. LS trans/clutch deal is the way to go sounds like
Thought about modding the TO bearing or fork to get a little more release out of it cant tell with a scattershield on it.
Sinking too much $ into this trans which doesnt even reeeealy need it. Doing everything new this time round
If its right then good otherwise I may just sell the car rather than do yet another conversin. Love it but the thousands dumped every time I turn around is just killing me.
Last time better be right this time. Yeah right
Old 10-30-2013, 08:52 PM
  #610
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Here is an option
http://www.dakotadigital.com/index.c...rod/prd886.htm
I Have not used this but I was planning to.
Old 10-31-2013, 06:46 AM
  #611
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Alloy!
I just crested the 3k mark with my alloy mechanical speedo conversion, not one single problem!!
Old 10-31-2013, 09:57 AM
  #612
Axle/Gears: 4.11
If I had it Id jump to have my speedo working. Have to wait next round.
Old 03-23-2014, 04:08 PM
  #613
Parrydise7's Avatar
Car: 1985 Camaro
Engine: .040" over 350
Axle/Gears: 9-bolt with 3.45s
Sorry to bring this back from the dead and I'm sorry if I missed the info in the thread.
Dyno Don and Anaheim Gear found what had to be the very last, brand new T-56 on the face of God's green earth. A great big thanks to both!!!!!!
It is now sitting in my Camaro, having replaced a T5 that sounded like death warmed over, after sitting on a shelf some place in Oregon for who knows how long.
As everybody knows, I had to add about a gallon of Dexron III. I wanted synthetic and that is what Don and I picked up.
When I went on the Tremec website FAQs I noticed that they DO NOT recommend synthetic and state it may void their warranty.
Regardless, I wish I'd gotten the T-56 far sooner.
Old 05-25-2014, 05:38 PM
  #614
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
T56 LT1 dust sheild
I just found this on ebay. I had to make my own dust sheild since mine didn't come with one.
I would have gladly paid $40 for one and not have to mess with trying to make one.
http://www.ebay.com/itm/301178301407?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 08-27-2014, 10:07 PM
  #615
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Guys..I detailed everything u need to know about a t56 swap and making the speedo work on a thirdgen in the below video..
91ORANGEZ28 (06-16-2023)
Old 01-03-2015, 04:05 AM
  #616
OzCamaroz28's Avatar
Car: 1986 Camaro Z28
Transmission: 700-R4
Originally Posted by AUS-IROC
I have read this thread all the way through and it has helped me decide to swap to a T56. The information you have posted will be very helpful i'm sure.
Since my car is already stripped and I happen to have a set of third gen manual pedals I thought I would mount them up. WRONG. When my car was converted to right hand drive the fire wall was completely changed. The steering column now goes through where the master cylinder should mount.
Hey Aussie. I know this is really old thread but did you ever do your T56 conversion...? I'm in Brisbane and about to get into a resto on an 86' Z28... it's RHD and auto but I'd much rather be driving a manual. There's most likely an LS engine swap on the cards too so makes sense to me but I don't know if I can do it on a converted car...?
Old 05-28-2016, 03:02 AM
  #617
delicious d's Avatar
I swapped into my 1987 auto camaro a ls1 and 6 speed from a 1999 z28, after installing a oem clutch master cylinder im having problems with the clutch not disengaging,, what do you guys think will be the solution? They are telling me to buy a adjustable master cylinder.
Old 05-28-2016, 09:18 AM
  #618
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Was it a new clutch?
Did you shim the throwout bearing?
Resurface the flywheel?
Old 05-28-2016, 03:50 PM
  #619
i pulled the motor and tranny out as one unit and put it in as one unit, the clutch was new before swapping. so i didnt tak anything apart. just bought new clutxh master cylinder and a set of 4th gen peddles and installed it. what should i do?
Old 05-28-2016, 03:52 PM
  #620
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Pull the trans and see what's in there! Pedals won't help.
Old 05-28-2016, 03:57 PM
  #621
im confused, so if the tranny was in perfect condition proir to swapping why would i have to pull it apart to see whats in there? I was think it had to do with the pedals and differents throw, thats why i was thinking clutch master would work
Old 05-28-2016, 05:18 PM
  #622
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Originally Posted by delicious d
after installing a oem clutch master cylinder im having problems with the clutch not disengaging.
Did you bleed the hydraulics properly? completely? Is the pedal squishy at all?
Old 05-29-2016, 02:45 PM
  #623
everything done properly,
Old 11-07-2016, 11:47 AM
  #624
Alaska Hwy 1Le's Avatar
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
So can anyone tell me how to hook up my torque arm? Spohn told me their x member torque arm mount kit won't work because its made for 93-97 t56. This is a brand new magnum from Chevy performance. Been waiting for Hawks to get back to me with solution but never heard back after they sent me this xmember and bracket that mounts to no where.
Old 11-07-2016, 12:47 PM
  #625
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
I added links to your thread... swapping-t5-lb9-305-a.html
Old 11-07-2016, 12:48 PM
  #626
You need to contact Magnum about this, or go with an aftermarket torque arm that uses a tunnel mount.
Hawks' X-member is specifically made for the GM T56.
Old 11-08-2016, 06:56 AM
  #627
Ed1LE's Avatar
Engine: 5.7, 5.0
You can also go with a tunnel mount arm such as the Alston.
http://www.jegs.com/p/Alston-Race-Ca...86412/10002/-1
https://www.thirdgen.org/forums/susp...ed-torque.html
Old 11-26-2016, 12:10 PM
  #628
Engine: 350 ZZ6
Originally Posted by Ed1LE
Thank you, I ordered sub frame connectors with crossbar to mount torque arm to. Also got the hawks sinister torque arm to go with it. Hopefully it works.
Old 12-08-2016, 09:30 PM
  #629
Ed1LE's Avatar
Engine: 5.7, 5.0
Awesome, keep us posted!
Old 12-22-2016, 08:19 AM
  #630
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
I'm finally doing the thing!
Questions:
-I've read through this thread and many others, and still haven't made a decision on the best pedal and hydraulics combo. Ive seen a few people mention the thirdgen pedal set with a fourth gen clutch pedal. Has anyone tried this yet? I like the "beefiness" and fitment of the thirdgen setup, but I want the engagement point somewhere around the lower middle of the clutch pedal travel with a nice friction zone feel that isn't horribly long. Best way to go about this? Heard that the Cavalier slave makes the friction zone very long and soft, and possibly towards the top of the pedal travel. Not entirely opposed to doing the turnbuckle mod or a Tick MC.
-The VSS goes off of the speedo in early CCC Qjet thirdgens, correct? If I have my tail shaft modded to run my mechanical speedo, that covers everything VSS and ECM related?
-Scatter shield: I have a stock 5000 RPM 305 now. Will be running the RAM SFI approved 18# aluminum flywheel and a SPEC stg. 1 or 2 (still undecided), ARP flywheel bolts, and the recommended PP bolts. Car will only be used for spirited street driving, autocross, and some HPDE/ hot lapping events. I feel like this may be overkill? But after reading horror stories, I'm kicking the idea around.
I've run across two options, the QuickTime and the McLeod. Pricing is SIGNIFICANTLY better on the McLeod, but there isn't much info on it. McLeod's website sucks. Any input there? I've done a few HPDE's and a drift event in my LS1 Formula and I've done several events (and many 6-7000 RPM clutch kicks) in my aw11 MR2 without giving it a second thought, but when researching the lightweight flywheel, I did begin to consider that I do like my legs, even if they aren't as pretty as the fairer sex's If I'm being paranoid, I'll just hold off and run the stock BH until I get around to throwing something together with a little more power and a higher redline.
Old 12-22-2016, 10:24 AM
  #631
alloy's Avatar
Car: 87 IROC-Z28
Yes the VSS is behind the speedometer and runs off the speedometer cable.
Its been 8 years since I did my swap and i used the 3rd gen pedals and made the push rod adjustable. Has been working perfectly for years now.
If you decide to have your tail housing modded for cable drive PM me. I am the one that does them.
Questions:
Old 01-16-2017, 10:13 PM
  #632
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I just finished converting from t5 to t56 in my 91. clutch pedal feels good and everything seems fine. when I release the pedal it does not engage until the pedal is almost out. it feels weak. same for in reverse. no noise or chatter. there is smoke and smells like burnt clutch. suggestions?
Old 01-17-2017, 07:22 AM
  #633
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
The linkage is "too tight" and is not fully releasing the pressure plate. This is similar to if you had for foot on the clutch pedal and not fully releasing it.
I assume you have an LT-style T56 with pull clutch. You can start by backing off the slave cylinder, put some washers (spacers) between it and the mount, and see if that helps.
Old 01-17-2017, 06:50 PM
  #634
jmd
jmd's Avatar
Did you have any history of the parts, or were they new?
Did you use a 93-97 master and slave or something else?
There are ways to change it, but clutch release is very quickly changed by changes to the "geometry" of things. Adjustable master cylinder pushrods might be something to try.
Old 01-18-2017, 12:52 PM
  #635
tonys91rs's Avatar
Car: 91 Camaro RS
Got t56 from a 95 everything came from the same car except the master slave assembly. It's the correct master slave. Got it used.It seems to be working. I was told the trans came out of a running car. Do I know absolutely the condition before I got it ? No.
Old 01-18-2017, 02:30 PM
  #636
tonys91rs's Avatar
Car: 91 Camaro RS
It did help a little. Reverse seems ok. But in first it. Feels like I'm taking off in third. The pedal also seems to be further out than before. I'm still thinking the clutch is really the problem
Old 01-18-2017, 02:43 PM
  #637
BOTTLEDZ28's Avatar
Transmission: A4
Using spacers where they dont belong isnt fixing the problem. I suspect the clutch to be the problem. You should have installed a NEW clutch assembly when you did this swap.
I did this swap on my last car back in 2002 and a new slave cylinder assembly was just about $150 from the dealer. No point in buying one from a junkyard when its that cheap at the dealer. Sometimes, spending a few more dollars actually saves you money in the long run.
Now, you you're going to have to do the job all over again and if you're doing it on your back then I feel your pain because I've pulled my T56 in and out of my car about 5 or 6 times over the past 10 years....on my back.
Do yourself a favor and buy a new clutch assembly and slave assembly. Make sure the flywheel is not worn down either. I had a SLP flywheel what I bought used MANY years ago and then had it resurfaced. Well, it must have been the 3rd time it was done because it was out of SLPs specs when I measured it. In the trash it went.
Old 01-18-2017, 02:47 PM
  #638
BOTTLEDZ28's Avatar
Transmission: A4
And there is no "linkage" in the LT style T56 setup. The slave cylinder is a pre bled part that simply bolts to the side of the transmission on the two long threaded studs. The ball on the end of the rod then sits inside the cup on the tip of the fork which then pivots on the throwout bearing which is pre installed on the pressure plate. If you do not get the fork fully seated on the throwout bearing then it will drop out and cause the other end of it to jam itself into the aluminum spacer. This will also cause the fork to rub on the pressure plate which will make a terrible noise.
Old 01-18-2017, 08:45 PM
  #639
jmd
jmd's Avatar
If you're running third gen pedals with 4th gen hydraulics, the master is moved quicker than in a T56 car. The stud on the pedal went higher in 93.
The pedals are very useable in a third gen if you want a more modulateable clutch pedal. Or the pre is a Cavalier slave cylinder that works with larger bore.
If your clutch isn't slipping more progressively in higher gears ( more in 5th than 3rd ) it may just be a case of the clutch engaging quickly and leading to slippage/grab that's very on/off with little in between.
Old 01-19-2017, 08:20 PM
  #640
tonys91rs's Avatar
Car: 91 Camaro RS
The hydraulics are good got them from a friend. The flywheel I just took down and got it resurfaced. The old clutch and pp was toast. New set up going in Saturday.
Old 01-20-2017, 07:25 AM
  #641
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
The flywheel could be the issue. With a traditional "push" pressure plate, cutting the flywheel will increase the PP-breaing gap and lower the pedal. Too far, becomes pushing the pedal to the floor doesn't free the clutch, leading to gear grinding.
The "pull" pressure plate of the LT-T56 means cutting the flywheel closes any gaps, becomes pre-engaging the PP, and not allowing the PP to fully grip the clutch, moves the pedal higher to fully engage... The washer/spacer is cheap, easy band-aid to determine if there lies the problem.
Additionally, that worn clutch disc (too thin) in this "pull" system causes the PP to have to extend further. This reduces the mechanical grip of the PP... As you extend a spring, the amount of force it can apply is reduced.
Old 01-22-2017, 07:57 PM
  #642
tonys91rs's Avatar
Car: 91 Camaro RS
All in and running. Seems much better although if I push the clutch all the way to the floor I hear a sound like the clutch assembly is rubbing on something. I checked the fork and it seemed fine. Suggestions!
Old 01-22-2017, 08:33 PM
  #643
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Typically, that is overtravelling, and the fork is contacting the edge of the pressure plate. Add a little more spacer. Or, put a stop block to limit the clutch pedal.
Old 01-22-2017, 09:30 PM
  #644
tonys91rs's Avatar
Car: 91 Camaro RS
Where do. Put the spacer at ?
Old 01-23-2017, 07:16 AM
  #645
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Spacer between the salve cylinder and the bell housing.
Old 01-24-2017, 12:25 PM
  #646
LT1/TA's Avatar
Car: 88 Sport Coupe
Axle/Gears: 4.56
Mine was rubbing on the pressure plate as well and I added a spacer and it worked fine.
Old 01-24-2017, 06:57 PM
  #647
tonys91rs's Avatar
Car: 91 Camaro RS
What kind of spacer ? This won't over extend the rod and cylinder from coming out of the slave housing?
Old 07-01-2017, 06:42 PM
  #648
online170's Avatar
Car: 1987 Firebird
Engine: 355
wow, what a mess. WTH photobucket....
Ill try to clean this thread up when i get a chance, i still have the original photos saved.
Old 07-05-2017, 02:01 PM
  #649
mars2878's Avatar
Car: 14 Charger RT rwd dd
Engine: 5.7L Hemi
Transmission: auto
thank you
Old 03-04-2020, 06:41 AM
  #650
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
Has anyone done the pull to push style clutch conversion recently? Im having a hard time finding a kit for the 2 piece rear main, and lt1 t56 combo. Any help is appreciated!!
Quick Reply: My T56 Swap Thread....
