trans shifting late
trans shifting late
I swapped the engine in my 86 2.8l camaro, I am not sure what trans it has in it but it is automatic and has 4 gears. After the swap my transmission shifts late. At about half throttle it shifts from 1st to 2nd at about 4500rpm. Please help me,
Adam
Adam
To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
1992 Trans Am
05-10-2023 07:19 PM
maroe624
04-16-2017 08:29 AM
