noob speed sensor question
Old 12-08-2009, 10:56 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Guys,
I am swapping my 1989 700r4 for a rebuilt 91 700r4. My question is the sensor toward the very back (i believe called the speed sensor) is different on my 89. Can I simply unbolt the 89 speed sensor and put it in the 91?
FYI - This is my first tranny swap, so have pity Also, I did several searches.
Thanks!
Old 12-08-2009, 11:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: noob speed sensor question
Yes. You might take note of the drive and/or driven gears to make sure the speedo will read correctly.
JamesC
Old 12-08-2009, 02:19 PM
Thanks JamesC!
I'm assuming if I swap the speed sensor, I will also swap the gear that goes on it so the speedo shouldn't change?
Old 12-08-2009, 04:07 PM
JamesC's Avatar
The driven will be fine, but there's also the drive gear to consider. As I understand it, the gear is much easier to swap in an auto than a manual.
JamesC
Caspar
06-19-2016 11:19 PM
ezobens
08-19-2015 10:29 PM
redmaroz
08-16-2015 11:40 PM
squiggy2
08-09-2015 09:30 PM
Quick Reply: noob speed sensor question
