Clutch question
Old 10-14-2011, 09:17 PM
TrucifiX's Avatar
Clutch question
Hi, I just had my clutch and flywheel replaced about 6 months ago and it was always easy to push in. Yesterday I noticed I pushed in about 75% of the way and than after that it gets harder to push in. Is this something I should be worried about or do clutches normally do that not long after they're first put in?
Thanks.
Old 10-20-2011, 11:10 AM
topless87's Avatar
Car: 1987 IROC-Z Convertable
Transmission: 5 Speed BW T-5
Axle/Gears: 3.08 Posi
Re: Clutch question
Check the clutch fork "ball" that mounts in the bellhousing. You can see it from under the car, it has a hex recessed hole that a large hex key will fit into. See if you can turn it and run it all the way into the bellhousing if it isn't. Ours was kinda doing the same and then we started blowing the end of the plastic slave cylinder out. After blowing out TWO plastic ones, we changed to a Wagner unit that is aluminum and that is when I noticed out clutch fork ball had worked its way out as far as it could come (it comes into contact with the trans housing after its quite aways out, so it couldn't fall out). After running that ball back into place with some silicone on its threads (I used to work for Cobalt Boats, they put silicone on all threads of there assemblys to keep nuts from vibrating off during use), it has stayed in place and no more "hard" clutch. If you push to hard, I would bet you will blow the end out of your slave cylinder also. Check it out, that may be your problem.
Drone358
09-01-2015 02:50 PM
87 camaro iroc
08-20-2015 07:47 AM
Bryan F
08-18-2015 02:28 PM
redmaroz
08-16-2015 11:40 PM
rsrmoore
08-07-2015 08:44 PM
Quick Reply: Clutch question
