TA not creeping in "Drive"
Old 04-02-2012, 05:57 AM
Blackknight's Avatar
Well I'm not sure if this is a Transmission issue or an Electrical one but I'll try it in this section.
I have following problem with my 89 TA with the stock automatic Transmission. When I put the car in "D" and remove my foot from the break it starts to roll, but it isn't limited, it can roll up to 20mph and it will even shift into a higher gear. I never touch the gas, the surface is perfectly flat, so basically when I am in a parking lot or parking structure I am constantly on the break cause I will be "rolling" too fast. Does anyone have any insight into this?
Old 04-02-2012, 01:58 PM
Killerz187's Avatar
Car: '91 Camaro RS T-Top
Engine: 383 Stroker
Transmission: Bulldog 700r-4
Re: TA not creeping in "Drive"
Check your throttle linkage, maybe it's not shut all the way?
Old 04-03-2012, 07:20 AM
Well I read that if that where the case the car would also idle pretty high but it idles pretty normal if you ask me. I'll snap a video when I get it out of the garage again maybe it will help with a diagnosis.
Infested
05-22-2018 11:56 PM
tommy z-28
10-06-2015 10:58 PM
MetalliCamaroRS
Theoretical and Street Racing
08-04-2002 03:44 AM
Greg Kuhlmann
06-02-2002 09:10 PM
rx7speed
18
12-28-2001 08:32 PM
Quick Reply: TA not creeping in "Drive"
