Will not upshift at WOT??
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
My stock TPI '86 IROC-Z will not upshift at WOT. It shifts fine at part throttle and normal driving. I have not tried the governor adjustment spring weight kit yet. The TV cable has been adjusted to the correct spec. I did replace the governor with one from a stock '89 IROC but it only changed the part throttle shift points slightly. The upshift delay is so bad, that I believe the engine would fail before it would shift.
I have read a lot of info about adjusting the shift points with the governor weights and springs. But it would be helpful to have it upshift first.
Thanks, Andy
WOW, I just realized that in a couple of months I will have been a member for 15 years!
Thanks, Andy
Re: Will not upshift at WOT??
Back when i owned an evo 5 lockout on upshifts would occur if the clutch pedal wasnt adjusted properly it wouldnt completely disengage and that would cause the lockout. Adjusted the clutch and then it was fine.
Car: 1982 Z-28
Thanks, Andy
1 Post
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Lower down in this section there is a how to I put together on how to enable the WOT 3-4 shift with pics.
OP I bumped my thread to bring it to the top. Have a look.
Car: 1982 Z-28
My transmission will not upshift 1-2 2-3 or 3-4.
Pac J
05-17-2020 10:44 AM
Damon
09-26-2015 04:29 PM
