Strange Slam from beneath the car
So , I was out driving the other day, used the kickdown function, and then: BAM!!!
Felt like I was gonna brake my spine. The "sound", or slam or w/e felt like something massive that hit the car just beneath/ in the middle of the front seats. Felt like the car was going to seperate into two pieces.
What was this? at first i thought I just hit an invisible roadbump or something but then it happened two or three times more. Only when I really hit the throttle..
Regars Simon
IROC 1990
Regars Simon
IROC 1990
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Strange Slam from beneath the car
most likely the trans rubber mount is done for. Not hard or expensive to replace.
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Only a few things that can cause that kind of noise in that area. Either the transmission smacked the tunnel because the mount broke. Or the tq arm mount is loose.
I replaced mine but it doesn't like the new engine and occasionally bangs. I'm going to have to install the ES mount I have I think.
Linson
08-21-2015 02:12 PM
