Need advice, Rear Axle
Car: 1985 Iroc, t-top
Engine: 5.0L HO L69
Transmission: Mt 5 speed
Axle/Gears: 3.73 Non Posi, Alum Drums
Finally working on 85 L69 Iroc (MT), rear axle is 3.73 non-posi. This thing 1 wheel peels in my driveway, and since I am rebuilding the car want to do something about the rear end. It has Drum brakes, but am not too concerned as I am not drag racing, just normal and spirited driving.
What should I do with it? Rebuild with a posi? Get a used axle with Posi(found one locally but it maybe a 273 ratio posi)? Bite the bullet and get another axle like this:
http://www.hawksmotorsports.com/hawk...-end-assembly/
Don't want to spend 2k. Any suggestions appreciated.
Also found this kit, would have to find shop to install:
http://www.quickperformance.com/GM-7...e_p_20410.html
Re: Need advice, Rear Axle
The Yukon Dura Grip from Quick Performance is a good differential and a good price. You will need a set of bearings and shims to install it. QP can supply them too.
Engine: 5.0L HO L69
Doing more research, thanks for that idea.
Read this while you are at it. http://www.nastyz28.com/forum/showth...t=install+posi
Works the same for the 7.5.
Engine: 5.0L HO L69
Was looking at these 2 parts kits. Would this be sufficient? (I think so)
http://www.quickperformance.com/ZK-G...l_p_17362.html
Checked the backlash on 3 separate occasions, .008 is my reading all 3 times.
Engine: 5.0L HO L69
Thanks for the advice, will place order tonight
