Rebuild a 350 or swap LS?
Old Aug 22, 2016 | 10:38 PM
89vertLI's Avatar
Hello all, I am new to the forum but have been lurking for awhile. I have an 89 iroc convertible with an older 350 crate and the following bolt ons:
Dart steel heads,tpis intake, mild cam, edelbrock uppers and lowers manifolds, large tube runners, 24# injectors,adjustable fuel pressure regulator, 52mm throttle body, edelbrock headers and 3" dual exhaust, ypipe. 700r4 has a shift kit. Emissions removed
My question is, in your opinion. Is it worth it to rebuild the block I have, or just swap in a 5.7 ls and tranny. I'm not sure how much power I am making now but would it be somewhat comparable to a stock ls? Any suggestions are appreciated.
Old Aug 23, 2016 | 05:01 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: Rebuild a 350 or swap LS?
For the cost to rebuild an old gen1 engine or even the cost of a crate engine in my opinion it's not worth it and I just did both. Just can't beat the newer technology. You can get a complete 4.8/5.3 anywhere from $300-700 all day long and they've been done so many times in these cars by now that everything has been figured out.
Old Aug 23, 2016 | 01:07 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Your car is already set up for the Gen I. A rebuild shouldn't cost more than $1000 (assuming you will tear out and install the engine once rebuilt) and the engine will have zero miles on it. It will cost you much more than that to swap in an LS motor with 100,000 miles on it.
Old Aug 23, 2016 | 04:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What's wrong with the 350 that requires a rebuild?
Old Aug 23, 2016 | 05:41 PM
89vertLI's Avatar
It doesn't require a rebuild, just want to give the girl some new life. Leaks a little, but nothing major.
Old Aug 23, 2016 | 08:04 PM
five7kid's Avatar
So you don't need to rebuild it because it's worn out. You're wondering if you should build it for more power.
Completely different answer, then.
A cam, higher stall (assuming auto transmission - you didn't say), gears, and tune can make a world of difference.
Old Aug 23, 2016 | 08:36 PM
89vertLI's Avatar
Yes more power and replace any parts that are worn.it has a cam, it has 3.73 gears. My question was is it worth it to rebuild what I have i.e. replace worn parts on the 350, or dump it all together and go with an LS. Being i am not going from a stock 350, I am torn.
Old Aug 24, 2016 | 11:25 AM
pancherj's Avatar
Car: 1990 IROC
The 350 in my IROC does just fine (typical high 11's, occasional mid 11's in the quarter when the weather is good). Spend your money on some nice aluminum cylinder heads if you have some spare cash.
LS motors are great and make easy power (mainly because of the better cylinder heads). But it costs a good bit of money to swap one in. It is not a $1000 switch.
evo-offer
Apr 2, 2016 04:42 PM
camaro1185
Mar 22, 2016 06:41 AM
1988_f-bird
Mar 15, 2016 01:06 AM
85ZZ4TPI
Aftermarket Product Review
Oct 5, 2000 01:31 AM
MochaX
Sep 18, 2000 05:41 PM
