Of valve covers and rocker arms.
Old 03-27-2013, 10:09 PM
Scoundrel's Avatar
Car: 87 Camaro
Engine: 2.8 V6
Axle/Gears: 3.42:1
So, when the topic of aftermarket rocker arms comes up, invariably advice pops up stating that fiero valve covers will be a necessity.
However, a web search I did today revealed the following:
http://members.shaw.ca/betterthanyou.../gtvcovers.htm
Here's the pertinent part:
Fiero covers have less underside clearance than the stock covers, so if you have large roller rockers you may have to clearance them or the valve covers so they wont hit.
I know that this page is speaking about s10's, but it definitely raised my eyebrows. So, here is my question: does anyone have any practical experience with placing aftermarket rocker arms (specifically comp cams 1.52 and 1.6 to 1 ratio) underneath both stock and fiero valve covers, or is this one of those myths that seems to get repeated because INTERNET?
Thanks in advance.
Old 03-28-2013, 02:04 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Of valve covers and rocker arms.
I used to have Comp Cams 1.52 roller tip rockers under stock valve covers with no issues. Just my .02
Old 03-28-2013, 09:02 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
As someone who's read a lot on here, they should fit. I've never heard from anyone with clearance problems, just rumors that only fiero covers work...
Old 03-28-2013, 10:25 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
ive used comp 1.6 roller tips under stock steel valve covers without issues
Old 03-29-2013, 01:39 PM
Scoundrel's Avatar
Car: 87 Camaro
Engine: 2.8 V6
Axle/Gears: 3.42:1
Okay, awesome, that's helpful. Can you guys share what sort of cams you were running with those rocker arms, or at least the valve lift prior to adding the rocker arms?
I'm a measure twice and cut it once kind of guy.
Old 04-03-2013, 10:57 AM
drdave88's Avatar
Engine: 6.0L
I was running a Melling MTC-5 cam.
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
New2Chevy
09-28-2015 12:35 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Of valve covers and rocker arms.
