3500 bottom end in a 3.4? Roller cam questions too
Ok guys I have a redundant question I'd like to ask. I was wondering if using a 3500 bottom end in a 3.4 block is feasible. I can get both easily. Also, how difficult would it be to convert a rwd 3.4 to use a roller cam?
Re: 3500 bottom end in a 3.4? Roller cam questions too
Yeah, that won't work out so well.
The cylinders don't have enough meat for to be safe, same reason it's not safe to bore out a 3.1 to 3.4 specs.
The block also needs to be clearanced for the 3500 rods due to the larger big ends, which may or may not be possible, leaning towards not or at least not worth the effort...
The small change in displacement will not be worth the effort. If you really want to have a 3.5L, use the LX9 bottom end, the improvements in the block are half of what makes it better than the the 3.4.
The most improvement to a 3.4 will be in getting it to breath better, meaning replace the top end with something better, best top end to start with is the LX9 3500 top end.
I see, the biggest reason I asked was ofcourse the use of a 3500 top end with 3.4 pistons makes for a bit high in the compression department, so I wasn't sure if using 3500 pistons would help. Any word on how to convert to a roller cam?
People have slapped roller cams in non roller blocks, without the oil restriction, but it wouldn't be how I would do it.
You can use LA1 (3400) pistons in the 3.4 and net approximately 9.6:1 SCR if you REALLY want to stick with a 3.4 bottom end.
UltRoadWarrior9
09-23-2016 06:38 PM
Ozz1967
09-23-2016 07:53 AM
