romulator
Old Jul 10, 2003 | 11:48 AM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
romulator
If some one that is running a romulator can enlighten me on the specifics, or give a direction on where I can do some research. Do you get to tune in real time? :hail:
Old Jul 10, 2003 | 06:26 PM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
yes u tune in real time, yes there is lots of info, including here and at tunercat.com(sopftware) and xtronics.com(hardware)
Called doing a search :-) lots of inof u need to dig up, it wont help u at all if u dont understand what is going on in the first place however, so make sure u understand the prom basics and work from there
Jeremy
PS there is liike 3 posts on the main page here alone if im not mistaken
Old Jul 21, 2003 | 09:00 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I've read through both sites and just want to confirm somthing. With the eprom emulator and the RT tuner there would be no need to invest in the pocket programmer itself right? The emulator is the burner itself in a way?
Old Jul 21, 2003 | 09:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The Romulator is meant as a development tool.
When your done, you should do a prom.
Old Jul 22, 2003 | 04:52 AM
JohnL's Avatar
...The emulator is the burner itself in a way?
Not in a way that can allow you to pull out the RT romulator and run without it.
And even if you decided you were going to leave it in after getting your tune right, you've got the possibility of losing the battery backup and not having any code to run the ECM.
One way around that would be to use the TC RT until you've got the tune sorted, then email your .BIN to someone to burn onto a memcal for you. You can see how this could be done with a memcal adaptor in Trax's PROMINTRO article.
John
Old Jul 22, 2003 | 07:23 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Okay, thanks for clearing that up. I just got a laptop so I can start doing some scans and thought if I could sidestep the burner and save a little $ I would.
Sp0nGa
Feb 16, 2009 02:36 PM
JPrevost
DIY PROM
Sep 13, 2005 03:51 PM
brennanw
DIY PROM
24
Jun 8, 2004 08:22 PM
Swapmaster
DIY PROM
Sep 4, 2003 10:15 PM
3.8TransAM
DIY PROM
May 18, 2003 09:12 PM
