EGR valve question....which one??
Old Aug 25, 2003 | 03:17 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Hey...I just picked up another manifold....its a Holley 300-64. This manifold has an egr provision on it and I have to run it where I live. Now the question I have is does anyone know what type of egr I need to run with this...ie positive or negative. Holley is absolutly no help and the old one will not fit the passage holes do not line up etc.
Oh ya...btw.....its on an 89 L03.
Thanks,
Dave
Old Aug 26, 2003 | 07:32 AM
Vader's Avatar
Most of the TBIs I've seen use a positive backpressure EGR. Most of the TPIs I've worked on use a negative backpressure EGR, mine included. Either way, you should be able to find a larger stamped "P" or "N" on the stock valve to help identify it.
Old Aug 26, 2003 | 07:40 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Thanks Vader....much appreciated
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
