swap project
swap project
My brother found an '89 formula with no engine or tranny, so we're thinking of putting the engine and tranny from his '89 firebird (V6) into the formula. Will this work? Just need some info if it is a possibility....what would have to be done to the wiring, engine mounting, etc., etc. etc.
Any input is appreciated
new motor mounts, wiring, ecm, and tranny. just the opposite of going from v6 to v8.
if that fomula was a tbi and you put a mpfi 2.8 or 3.1 you will also need a different feul pump, one with more pressure.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Don't waste your time and money, I have a nice TPI 305 w/auto I'll sell ya. (from my '90 TA) Or I can make it TBI if you want.
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Keep it a V6, just change it to a Buick turbo. That will blow away the 3rd and 4th gens. Its probably less work and a whole lot faster
Car: 1988 Camaro Convertible
I've got a 305 here as well, but it's a l03, however I do have a almost complete TPI setup for sale as well. Including an Super Ram manifold.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
'89... You can put a Turbo Buick engine in anything 1989 or earlier. But for '88 and '89 you have to use the '89 Turbo Trans Am version.
Guest
Posts: n/a
Hogwash.
"Certification Standards
Make sure the engine and emission control configuration on exhaust - controlled vehicles are certified to the year of the vehicle or newer, and to the same or a more stringent new vehicle certification standard."
Thats the law. Thats how Chevy engines end up in Jags, Toyotas, and Mazdas and are legal in this state. Red tape parade ensues.
Here is the fine print:
"Mixing and matching emission control system components could cause problems and is generally not allowed."
TTA- The TTA is the 20th anniversary of Trans Am's not Firebirds, hence, 1969+20.
I've actually done some minor research to this and I have two things to add:
Research tells me that you can put in a buick motor, however the F body version simply used different heads. They used heads from a FWD version. I guess they are skinner. But basically same motor. I heard you can use the buick in an F body, but its very "tight". I have a line with a guy back east who will sell me a Turbo Buick 3.8 from a 1987 GN. Shipped from port to port for $2750. I love the 89 TTA's and doubt I'll ever own a real one. After reading up on them and seeing some amazing GNX's, GN's and TTA's run, I really want to drop one in my 1987 TA.
Since its an 1987 motor going into a 1987, it should be cool, right??
Second, I need to hook up with a pal of mine who, also is making his 1983 (?) Trans Am into a Knight rider mock up, and is also going the way of the Buick Turbo 3.8. He's not using the TTA Version. Which I'd imagine would be hard to find.
Any how..... just my thoughts.
(((And thanks Brit for forwarding me the link!!)))
Fast355
Dec 2, 2016 06:33 PM
ambainb
Apr 25, 2016 09:21 PM
