Better When MAF Disconnected
Old Nov 6, 2003 | 12:32 AM
Black IROC 86's Avatar
Car: 1986 IROC Z
My car runs better when the MAF is disconnected, what would cause this? My MAF was hanging bout 2 months ago and was 1 of the 5 pins got ate up by my alternator band.
Any help on whats goin on here?
Old Nov 6, 2003 | 12:55 AM
bigals87z28's Avatar
Car: Check The Sig
ahahah im gunna take a stab in the dark but... you have a bad maf!
It runs better because the computer has a set of "limp home mode" presets so incase of a sensor malfunction, you can get home and fix it. Its a back up device. Get the Wells Su-145 mass air flow sensor, and make sure this one doesnt get beat up by the alt ok? Good luck with the car.
Old Nov 6, 2003 | 01:18 AM
Car: 1986 IROC Z
How much do these run for?
Old Nov 6, 2003 | 01:27 AM
Car: Check The Sig
165 at your local parts store. At least thats what i hear around here...
Old Nov 6, 2003 | 10:43 PM
Car: 1986 IROC Z
ok, i went the the local kragen, i asked to see the Mass Air Flow Sensor and they brought out the whole big peice that goes under the little sensor connects to. All i need is the sensor that connects into it, comin from the wires n all that cuz 2 of the little pins got ate up by my alternator band.
What do i ask for when i try to get the piece?
Old Nov 6, 2003 | 10:59 PM
Car: 1986 IROC Z
ok, i went the the local kragen, i asked to see the Mass Air Flow Sensor and they brought out the whole big peice that goes under the little sensor connects to. All i need is the sensor that connects into it, comin from the wires n all that cuz 2 of the little pins got ate up by my alternator band. I dont think i need the wholke peice just the little sensor.
Old Nov 6, 2003 | 11:17 PM
Car: Check The Sig
it shoudl just be a plastic tube with the sensor inside, and on the "bottom" of the sensor should be where you plug teh maf in... its all one piece.
Old Nov 6, 2003 | 11:56 PM
Car: 1986 IROC Z
i opened the box and it was just the plastic tube there was no little sensor thats why im askin for the name of how to search for the little thing
Old Nov 7, 2003 | 01:22 AM
GTA88's Avatar
I think you mean the "connector" that plugs into the maf sensor, right ?
Old Nov 7, 2003 | 03:22 PM
Car: 1986 IROC Z
Yeah Yeah where can i find that?
Old Nov 7, 2003 | 03:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can usually find one in a junk yard, just cut it off with plenty of spare wire and splice it in.
The Trickster!!!!!!!!!
Old Nov 7, 2003 | 04:16 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
the connector does not have to be off a v-8 TPI car. it can be off a v-6 car. they work also.
Old Nov 7, 2003 | 09:04 PM
Car: 1986 IROC Z
thanks i found it for 17 at the local Napa.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
