All Go Here Posts...
Old Dec 31, 2003 | 12:05 PM
snflupigus's Avatar
"ALLGOHERE" Posts...
In an attempt to clean up redundant posts because people (new and old) are not searching first or reading other articles at all, I am asking all to post their related questions within one large post. Eventually these ALL GO HERE posts will contain all the information you need on this topic. (either within or linked to other posts).
People who have been around a while... Please check these posts regularly to help out..
Of couse, anyone, always search first and read the other posts first.. I dont want the same answer comming up in these ALL POST HERE posts multiple times either.
If you find the answer to your question in another article, LINK TO IT so you can help others. After all, thats why we come here.
Later... when it might not be a common question. You can search for ALLGOHERE posts because it is one word.
Thank you all for your help in trying to keep this board easily usable...
any questions... email me. SNFLUPIGUS@HOTMAIL.COM
Old Mar 2, 2004 | 04:54 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
FROM HERE ON OUT!!!
I have just unstuck all the ALLGOHERE post from the top of the TBI forum. This DOES NOT mean they no longer exist! All this means is now you simply just click on the SEARCH button and type in ALLGOHERE. This will bring up all those threads. I wish for everyone to still use them! Thanks everyone!!
Bruce (90RS305)
Old May 24, 2006 | 08:17 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
If i get a cam a little hotter than the LT1 cam will i need a new TBI Unit and a Fuel Pump? If i dont need a new TBI Unit, if i did buy one would it add power because of the cam?
Old May 24, 2006 | 08:58 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
wow you either knwo nothing about much of anything
(engine wise) or just worded that ignorantly.
Anyways yes a cam such as that which i'd considering massive compares to a stock l03 cam or such (paperweight) would most definetly add power but, only under a correct state of tune.
Theres numerous people that have tuned the proms after as little as a full exhaust and gained some good power and drivability from doing so, so i'm sure the addition of a mild cam would realy throw it off big time.
Old May 25, 2006 | 08:17 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
your answer didnt come close to answering my question.. duh a cam adds power.. but i was reading up about the stock fuel pump and the tbi unit and i found mixed answers whether i would need a better one if i bought a cam
Old May 25, 2006 | 10:02 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Well it could go both ways but I would say your stock pump could do it with the right tune but if you put on a bigger tbi unit you would have to go to a bigger pump to match the greater air flow. I powered my 350 to a 14.1@98 with the stock pump and modded stock tbi unit but as soon as I put the holley tbi base on I had to upgrade my pump and tune and then I ran a 13.8@105 so I hope this helps you.
Old May 25, 2006 | 01:40 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
with getting a hotter cam, will i need to do anything to the engine besides tune it? Example: Will i need bigger injectors etc?
Old May 25, 2006 | 06:27 PM
snflupigus's Avatar
why was that question posted under this thread.... what happened to moderators?
Old May 25, 2006 | 06:42 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Ours don't seem to be around very much anymore.
Old May 26, 2006 | 02:00 AM
snflupigus's Avatar
maybe its time for a comeback I'm game.
Old May 26, 2006 | 05:31 AM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Well you just pretty much answered your own question if you knew that the cam added power then didn't you........
How do you get power on an engine?, you increase airflow so you can burn more air and fuel. If you have more air then naturally you will need more fuel. You can increase fuel by increasing pressure but, at some point the stock throttle body which supposadly flows about 500cfm (or a little less actually) will become a restriction. although people have proven that they can flow 300hp through them. As for using the stock fuel pump you probably could but, no one would reccomend it.
Old May 26, 2006 | 07:48 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
dude i didnt ask if a cam adds more power lol...i was asking if a new tbi unit after getting a cam would add power
Old May 26, 2006 | 04:55 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
and i aswered it, all i said is if you used your head you would have already known the answer.
Anytime you increase airflow you increase power if you have the fuel to do so. Although just like anything on an engine you can't just add 1 very good component like a huge cam in or 195cc afr heads on with all other stock components and expect to notice a huge gain. Basically you have to find the bottleneck and eliminate it.
The bottle neck on these are cam exhaust and then foll0owed by heads and manifolds.
throttle body is probably last.
Old May 31, 2006 | 05:27 PM
90RS305's Avatar
100,000 things going on all at once...at least thats why I haven't been on as much. Anyways, this isn't the right thread for any of this info to go under, this is simply a thread to let people know about the ALLGOHERE search topics.
ericjon262
DIY PROM
Mar 2, 2014 01:06 PM
JMoore17
Aug 19, 2013 11:10 AM
Bullydawg
Northern California
Apr 30, 2011 07:27 AM
bonesbrakr
Classified Ads Feedback Board
Oct 15, 2009 07:02 AM
