Oh, By the way.....................
Old Apr 26, 2004 | 06:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
1. Car will not start unless dash harness BLue plug G, Pink wire, IGN Power for TCC stop Lamp is actually powered
2. Car will not shut off unless ICM is powered w/acc switched power
3. Car will not accelerate faster than idle if throttle cable not hooked up
The fix:
1. Apply power to said wire, turn the freakin key, and
2. Got some more wiring to do. Also wire up the radiator fan while I'm at it
3. Connect it. DUh!!!!!!!!!!!!!!!!
Old Apr 26, 2004 | 09:54 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Sounds like you've had a blonde day
Old Apr 26, 2004 | 10:08 PM
Engine: 5.7 / 7.4
you have noooooooooooooooo idea how much it was pissing me off this last week. That one stupid wire keeping it from running
Old Apr 26, 2004 | 10:15 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Ouch.....
But, yay for you! Nice to hear the problem(s) are solved... those kind of things are the worst though.
Old Apr 26, 2004 | 10:48 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
congrats on working out the gremlins, that's the one thing i'm not looking forward to in my future swap, and that's exactly why i'm going to be planning it forever. Although, i know for a fact that i'll have the same trobules as you are, probably on a higher scale...good work.
Old Apr 27, 2004 | 12:18 AM
FbodTrek's Avatar
Are you
Are you gonna still do the northstar swap? Just wondering, personally, Ive worked on enough Cadillacs to know, those motors are a PITA! Head bolts usually strip right out of the block too....
Old Apr 27, 2004 | 12:14 PM
85f-bird's Avatar
Engine: 2.8L, LS1
yeh, still going to do the Northstar swap....got the heads off w/o any problem, although i do know that installing and removing heads can cause a big prob, in other words they don't torque like they're supposed to. I"ll be starting the rebuild of the engine this summer (gonna cost an arm and a leg) but if it's reliable, it'll be more worth it in the end.
Old Apr 27, 2004 | 12:48 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
nate, remember what I did to my s10, then tell me I have no idea how pissed you were
Glad to here you making progress.
Old Apr 27, 2004 | 12:54 PM
Engine: 5.7 / 7.4
yeah, a brotherhood of diss'd DIS
makes me wonder about the other wires not hooked up.
Old Apr 27, 2004 | 01:12 PM
Dale's Avatar
Engine: 350 S-TPI
i had a few not hooked up also
Old Apr 28, 2004 | 08:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Glad to hear you got it going! #3 sucks, though. I'm Workin' on a friends' dad's S10 blazer w/the 4.3 Vortec; the nut kit (plastic fuel lines!) sprung a leak inside the intake. It's got a fancy clip that holds the fuel lines to the CPI injector. I'm slowly prying the clip off- ZING! Right behind the engine.
Well, no big deal... GM manual says to replace the clip- it must come with the nut kit. Bzz, wrong, it comes with the $500 CPI spider unit. So this weekend I gotta dig around and see if I can find the clip. Oops, no, I mean I HAVE TO find that clip.
Saw a northstar v8 crammed into the back of a Fiero at the Englishtown swap meet a few weekends ago- that was hot! Car didn't even look like a Fiero anymore... I felt cool because my tip-off was that there was a stereo under the front hood... told my buddies "I think that's a Fiero!" I was so happy when I was right! (I bought an o-ring kit and a hose crimp-off tool... nothing cool to talk about.)
Old Apr 28, 2004 | 09:08 PM
Engine: 5.7 / 7.4
$500
It only cost me $315 for my injector (Yes, I too am blessed w/a 95 Blazer w/no aftermarket )
Old May 8, 2004 | 02:20 PM
Engine: 5.7 / 7.4
to keep from over hijacking another thread
Originally posted by FbodTrek
You only paid 200 BUX for that 3.8?!!!! Lucky bisturd You see that post about the stage 2 NA cam at firebirdV6.com? 13.3 second 1/4 mile. I wish I would have gone 3.8, but I'll settle fora high 14 second run, lol. How's that coming by the way?
I just need to get a y-pipe made, properly, and changeout the brake mster cylinder. Trouble shoot the tach hookup, & see which of 3 wires will make the VSS speedo work. Hook up the the air intake, maybe Home Depot brand again, and that's preety much it for the big stuff.
Old May 8, 2004 | 07:09 PM
Engine: 5.7 / 7.4
Old May 8, 2004 | 08:58 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Dont you just feel stupid when it turns out to be somthing dumb like that. I know I do. Anwayz, on getting it going again.
