Offset Wristpins, Whatsit Do ?
Old Oct 7, 2004 | 12:02 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Just wondering about offset pins.
I realize that by offsetting the pins in relation to the crank rotation, the rod angularity is changed slightly. But what exactly are the benefits of this?
And what are the disadvantages?
Are offset pins good for performance apps?
Anyone know?? Thanks
Old Oct 7, 2004 | 12:14 PM
Damon's Avatar
Many stock pistons have the wristpin offset about 1/32". Helps reduce piston "slap" (rocking of the piston in the bore) as it passes TDC and gets pushed on during the power stroke. Reduces noise and wear.
Ever wonder why most stock pistons have a little notch on the top that must point towards the front of the engine regardless of which bank you install them in? This is why.
For power production it doesn't mean a whole lot. We're talkiing very very slight differences here.
Many aftermarket pistons don't have any wristpin offset (wristpin is truly centered).
Old Oct 7, 2004 | 12:49 PM
Car: '85 IROC
Engine: LB9
Hmmm... So If I'm given a choice between offset or centered which should I order?
Old Oct 7, 2004 | 12:52 PM
Damon's Avatar
Buy the pistons that are right for your application. If they happen to be offset, use them. If they happen to be non-offset use them. If all else is truly equal (and it never is) then I go for non-offest if it's anything other than a stock rebuild.
Old Oct 7, 2004 | 01:04 PM
Car: '85 IROC
Engine: LB9
For a 350 using flattops there are a lot of different choices.
Thanks tho
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
rb85TA
26
Sep 14, 2015 10:29 PM
