1LE 9-Bolt question
Old Jun 26, 2005 | 10:08 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
1LE 9-Bolt question
He guys, I need some help. I want to do the the 1LE upgrade on my 88 iroc. I need some info on the rear. I have a 9 bolt, what do I need as far as backing plates? Will ones off a 10 bolt work or will ones off of a 93-02 work. I can get a PBR setup from a 10 bolt or there are lots of parts on ebay from the 4rth-gen cars. If I get the 10-bolt stuff and I need a 9-bolt backing plate can I get them cheap?
Old Jun 26, 2005 | 11:17 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Here is the best route to go, get a hold of ed miller he has complete kits cheap, high quality stuff with an excellent rep around here.
I am doing a c4 upgrade on two birds and a rear PBR upgrade like you on one. ebmiller88@aol.com
Old Jun 26, 2005 | 11:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No the backing plates off a 10-bolt will not work.
No the PBR calipers will not work on your existing backing plates.
The only thing you can do, is to try to find a pair of 9-bolt PBR backing plates. They are not plentiful at all. There's thousands and thousands of people trying to chase after both pairs that are available in the world at large. Well, maybe there's 3 pairs.... but I doubt it.
Old Jun 26, 2005 | 05:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check with Andy. He may be able to help: http://www.andyz28.com/
JamesC
Old Jun 26, 2005 | 07:24 PM
Redbird87's Avatar
backing plate 9-bolt
I know where a spare pair of backing plates are, must be one of the three??? Dave
Old Jun 26, 2005 | 08:38 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
I got mine on the car last week, so there's one more set accounted for. That only leaves one. Good luck, young grasshopper.
I thought someone was making/supplying the 9-bolt PBR backing plates now.....maybe it's just wishful thinking though....
Anyway, if you can find the backing plates, the calipers and brackets off an LT1 car will bolt right up, they're the exact same thing. The backing plate is the only difference.
Old Jun 27, 2005 | 05:39 AM
JamesC's Avatar
AndyZ28 was/is making them. Check the following link for pics of the differences between the two backing plates:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
