brakes freezing and fading, new motor
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Well, the car has sat for 4 years,...finally got the new motor in and : my brakes are very stiff and hard to push, and sometimes the calipers stick like they are fozen, even with my foot off the brakes. The car chatters when i go foward...then it seems when the motor got hot before I lost brakes completely, not even moving fast....like brake fade. ideas?
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Are the rotors rusted? That could be one solution right there. If they're not, take the caliper off and pull back the rubber boot covering the pin the caliper slides on. That could need greasing, or it could be rusted. If all that's fine, double check all your vacuum lines to the booster.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
