"Complete Serpentine Belt System".....
Selling off a serpentine belt system that was removed from an '89 Trans Am. Setup comes with just about every pulley, such as; crank pulley, power steering pump pulley (pump included), waterpump pulley (pump not included), alternator pulley (alternator included), however, the only thing that does not come w/this setup is the A/C compressor, nor it's pulley. Pictures will be up shortly, just waiting for my phone to charge....
-Rob
-Rob
Re: "Complete Serpentine Belt System".....
^ I might even include an A/C delete pulley w/the setup for you guys.....
Here's a pics of this setup, please note that the smog pump has been removed awhile back, and although I do have the pulley (as seen in the pic), you'll need to grab yourself a used smog pump, and/or smog pump delete pulley itself. Also note that the alternator w/pulley is not in the pic, but it will be included with the purchase....;
Originally Posted by Mkos1980
Looks like an underdrive crank pulley.
This is the reasoning why I didn't include a picture of the alternator yet, as I needed to pull the alternator w/pulley, as well as the crank pulley, from my '91 Formula. Ultimately, the underdrive setup (crank and alt) were going on the Formula, but if you guys want it included w/the serpentine setup as a whole, this can be done, too....
Car: 64 Impala, 86 Z28 Camaro, 00 C5 FRC
Price shipped to 60438?
How many miles on the setup?
I would be interested in the setup with the underdrive pullies, and i already have an AC delete pully so i dont need the one you have.
Also do you take paypal?
-Richard
-Richard
Again, just to answer a few more PM's, the alternator will be included with the setup, as I'm trying to make this as much as a complete set as I possibly can for you guys. The picture of the alternator is a tad blurry (which is a 105 amp), but is embellished as follows.....;
RPM VOLTS AMPS
3000 14.7 50
5000 13.4 105
RPM VOLTS AMPS
3000 14.7 50
5000 13.4 105
Car: 87 GTA
How much for everything, to swap from v-belt to serpentine?
I have a power steering pump w/hoses and the drivers side bracket, but that's the extent of what I have already.
I'm going to give this a quick bump because I've decided to include this as a package deal. I'm offering this engine w/forged crank and the Summit Racing cradle, w/the complete Serpentine Belt setup in my signature for $300.00. This is a very good deal for any engine builder, not just third generation enthusiasts. Package includes....;
Engine Including;
350 4-bolt main engine w/one piece rear main seal
Factory GM forged crankshaft
Main caps w/bolts
Summit Racing engine cradle
'89 Serpentine Setup Including;
105 amp alternator w/pulley (underdrive or OEM, your choice)
power steering pump w/pulley
crank pulley (underdrive or OEM, your choice)
waterpump pulley
smog pump pulley
a/c delete pulley
driver side & passenger side brackets
Engine w/serpentine setup is already bolted to the engine stand, for those who live in the area, it would just be the matter of coming by with a pickup, and wheeling the assembly on. We're talking three minutes from my garage, to your truck....
-Rob
Engine Including;
Main caps w/bolts
waterpump pulley
smog pump pulley
a/c delete pulley
-Rob
^... engine is not setup for roller lifters, although it can be tapped for the roller lifter retainer. When the engine was pulled a few years back, it had less than 100,000 miles on the clock. I would definitely recommend an engine hone and bearings either way with any engine buildup.
-Rob
-Rob
Here is a picture of the lifter valley. The posts are definitely there for the roller lifter retainer plate to be bolted to, they just need to be drilled and tapped, as these engines were released w/out roller lifters from the factory....
-Rob
-Rob
