Interests in my custom 3inch chambered tube catback??
I decided i will no longer need this setup for my new motor build, and rather than chop it up to use for fabrication of new exhaust, i thought i'd see if anyone would be interested in it
The exhaust started as a Flowmaster american thunder setup. I've since then installed a powerstick chambered tube into the I pipe section. Cut off over the axle, and then had a custom stainless exhaust tubes tail pipe section fabbed up with summit 12inch long 3.5" tips put on. 3inch i pipe over the axle goes into a magnaflow mini ypipe splitter and has dual 3inch exits
System is FULL 3inch to the tips. Will hook up to factory single cat cars. Sounds great. Around 370 invested to build it, i'll let go for
200 plus shipping, which i THINK will be somewhere in the 50 buck range but not sure. System is still on car but i can have it off this weekend. I will have to cut into some sections to ship. Any exhaust shop should beable to put it together. Rear hangers are on the rear tail pipes that will hang from rear frame rails. Can include the hooks for that
PICS and CLIPS below. This was on my bolt on L98
http://media.putfile.com/Chambered-Tube-exhaust-clips
On the dyno, ok quality sound
http://www.youtube.com/watch?v=Xv-DllPZoWo
Re: Interests in my custom 3inch chambered tube catback??
it fits pretty good. my y pipe and cat sagged alittle since the cat support bushing broke off and i never replaced it. So it sat alittle lower than stock but my car is lowered a good 1.5" in front, 1 inch rear atleast. If your system sits up high, it will be fine. You can tuck it up higher at a exhaust shop tho.
I'll get it off the car either tomorrow or friday and i'll get a weight estimation on this setup
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
thats a reall nice setup i would so buy that if i didnt just buy a magnaflow. nice car to btw
and no you dont have to drop the rear to put it in. you do have to lower the rear down all the way and get the car up higher to slide it over the axle tho. Its in 3 pieces now like the SLP loudmouth kit. it will need to be welded together or buy slip fit connection pieces inorder to have it clamped together
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
But if you look it is not mandrel bent and does not include a chambered muffler.
Bump for a nice setup!
I want it bad, but I don't have a 3" exit y-pipe.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
still available?
morrow
01-13-2024 12:29 PM
Hotrodboba400
12-10-2019 07:07 PM
