BBS Designs Single Turbo Manifold
Bought this off a member here several months ago and I never used it. He never used it either.
I was gonna put this on my 383 turbo build for 550-600whp but I decided to go with a larger motor and more power, and twin turbos
This is a great manifold for mild motors as it features a 2.5" sched 40 pipe with about a 2" ID feed tube which i feel is abit too small for a 383 or larger motor for over 600whp which I'm gonna be well over.
Primaries appear to be about 1 5/8 OD and are sched. 40 pipe. Real beefy setup.
So got to get rid of it. I kept it in case i couldnt fabricate these twin manifolds but i got them 90% done, so the BBS has to go.
T4 flange with 38mm wastegate flange.
Pittsburgh PA, looking to get 425 shipped. Let me know
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: BBS Designs Single Turbo Manifold
My cousin called me last week asking me to make his friend twin turbo headers... I'll call him tomorrow and see if he'll settle for a single turbo. Was this for the V-belt or the serpentine belt accessory drive?
Bump,
Looks like it will not fit L98 Angle plug heads like AFR L98 angles, the plug is pointing right on the main tube.
Looks like it wont fit tall valve covers, and it looks to be for V-belt setups. AC will be right on the inlet housing
Car: 1988 Firebird Formula 350
Axle/Gears: BW 3.27
There go my plans. Nice manifold for someone though.
Axle/Gears: BW 3.27
Not really going to have the cash to do the whole setup and i'm not one who likes to put parts on the shelf to be used later, kind of impatient. I'll end up maxing out another credit card to get it done and thats just not a good thing to do.
Car: 55' Chevy, 57' Plymouth, 67' Camaro
Engine: TT406, NA440, 230-6
Transmission: TH400, 727, ST10
Axle/Gears: 9" - 2.75 gear, 8.8" - 3.27, 10bolt
I have made turbo headers like this before and they are actually really efficent since the thick wall help keep the heat in. I used Schedule 40 Weld-els.
Car: 92 Z28
Engine: Boosted LSX
wanta trade for a SD harness and ecm you could use?
Only ask cuz I have some parts to add with your header and provoke my buddy to turbo his car. He wont spend $ on a setup so Figure its something I could say Hey look what I have you can use....lol
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
ok im lookin to do a single set up sience the twin headers wont b a bolt on could you pm me a link to where i can get them, and is it only one side and you make the crossover from the drivers side?
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
dimented24x7
09-06-2015 03:51 PM
