90-92 AC compressor connector and diode
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 90-92 AC compressor connector and diode
I have a couple of those if you mean the ones that clip on to the compressor with two spade type terminals. They have a rubber boot over the connector and is at a ninety degree angle to have the wires going to the rear rather than stick straight up. $20 shipped to you priority. Send your email address if you want pics, Henry
I know the ones you are talking about. Mine doesnt have the spade. This compressor actually has two connections on it. The one I need is on the top, but instead of spades it has the small round male connection.
All I really need is a diode. I have some connectors that will work, just no actual plug. I could make it work by going to a electronic store and buying a diode, but getting the factory thing will be cleaner looking in the end.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Snap a pic of the plug you're needing. Ive got about 50 AC connectors with diodes, but the style changed quite a bit over the years
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've got several of the ones like the ones on my 92. The front one has two clips on the side to hold the plug in and the back one is the roundish one with one release tab. I can send you either one for $10. Send me your email and I can send pics to make sure we're talking about the same thing
I can take a pic later tonight. If my memory is correct, its exactly like henry3d described.
Now Im just debating on spending $1 on a diode from radioshack and rigging it up, or buying the correct connector.
I hate how a rigged car looks though. IMO, wiring apperance makes or breaks a modified car. Thats why you wont see any pics of under my hood until after I rewire everything.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yes, I just sent you another email with details. I sent an email yesterday as well. You didn't get that one?
if anyone else is looking i have a 92 harrison compressor and wiring and all that still on an engine in a vehicle im parting out now, as of yesterday. same as in the pic above.
lemme know
pm email or text me 217 671 7792
it is a TBI engine
if you need or have specifics then let me know and we can talk
lemme know
it is a TBI engine
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
