Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Need help to specify an AFR head
Old Apr 30, 2002 | 12:19 PM
primo's Avatar
I need help to specify an AFR 190 head for a 350 TPI for an 87
Iroc. There is some extra machine work needed on the heads for a TPI unit , if you had ordered before please help.
I may used this heads on a stock 350 L98 block or a 383 strocker 1971 block, 4 bolt main.
Thanks for your help,
Old Apr 30, 2002 | 01:19 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I'm right in the middle of installing a new 383 with a set of AFR 190's 68cc w/L98 plug angles.
I have the invoice at home with the part number but I think it's AFR# 1022. These are not in their catalog. I called AFR and talked to Mark ext 107.
I told him what I was doing with my 88IROC and what I needed for the spark plug and header clearence and said L98 angles work and he said we have part number just for that. I went with the 68cc for higher compression.
The only extra machining needed was to have the heads drilled and tapped for the sensors. I think that was like $20 each hole.
I'll get that invoice and post more tomorrow if you would like.
Old Apr 30, 2002 | 05:49 PM
primo's Avatar
Thanks for the reply Dwayne, please post the information.
Old Apr 30, 2002 | 06:15 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Check out their web page http://www.airflowresearch.com/
They have the 190 68cc L98 plug angles under part # 1018.
But I don't think those have the heat riser cast into them. I live in California and am trying to get this to pass smog as a 350. At least I'll pass the working EGR test.
The 1018's will pass smog if you got the corvette route of drilling out a hole in the header or manifold and route the exhaust gasses to the manifold.
I'll post the invoiced part# tomorrow.
Old May 1, 2002 | 12:14 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Ok I ordered AFR# 1022.
So it's like I said above.
190cc, L98 plug, 68cc Chamber CNC street porting
W/ xover or heat riser = 1022
W/out xover = 1018
If you want them in 74cc Chamber the part number w/heat riser is = 1017
I hope this helps!
Old May 18, 2002 | 11:13 AM
primo's Avatar
I'm also working on a 383. With 68cc heads and a 3.75 stroke, what rod lenght and piston did you use. I like to keep the compression ratio around 10:1 to 10.5:1, to be ablee to use pump gas.
Thanks,
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
