Need CAT for 3" SLP bolt on exhaust and slip on header pipe
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I am going to be getting the SLP 3" exhaust with 2 bolt flange. I am also adding the SLP headers with slip on adapter.
So I will need a 3" CAT that has 2 bolt flange on the exhaust side and 3" slip-on on the header side.
Does anyone know where I can get a specific CAT for this application??
Second the Catco from Summit. I have one on the same SLP system you are getting. P/N I used was CTO-9118, but double
check on this.
check on this.
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I don't know about the SLP setup, but I've got that Catco direct fit cat (direct fit for 86-92 single cat TPI cars, 3". around $117) and it bolts right to my Hooker cat-back and slips right on my Edelbrock TES headers, both of which were also purchased for a 86-92 TPI car (meaning 3" stuff).
Car: 1991 Conv. TA
By the way, can someone please post a photo of the cat and exhaust.
Also, the CTO-9118 does have a 2 bolt flange, right??
Thanks.
Thanks.
Car: 1991 Conv. TA
Hey Z28DJP1987,
I need some help on the CAT part #, see post below. Or did you drill the two holes for the SLP flange???
Here is a post from 92GTA:
Judging by the picture of it on Summits web site:
That's not it. The SLP 2 bolt flange on the 31008 does not look like it would bolt up at all. I'm getting my GTA back from the shop tomorrow and I'll take a picture of the flange and post it here. That's actually a direct fartory fit cat according to the description.
Here's a pic of the SLP 2 bolt flange off of their web site:
I suppose it would work if you drilled another hole between the 2 holes on the right hand side of the flange on the cat and it would line up alright.....
LT1Formula
20
11-14-2015 12:02 AM
transaero
08-31-2015 01:14 AM
