AGR Steeering boxes
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
AGR Steeering boxes
Ok so what ya all think about AGR sterring boxes. From what I have read people seem to like them . Also to what should I go for, the varible power assited ratio or the 12:1 box?
Personally I like the idea of the varible ratio box casue I am a lazy pos =) hehe but a friend of mine brought up a good point about the VR box. Their is more stuff to break in it.
Here is the page where the boxes are at.
http://www.agrsteering.com/STREET/street.htm
Kat
90 RS 305 TBI A4
Dumb ***/**** poor/orginating memeber of the infamous NE Crew
Time to see, believe this in me,This pain that i feel deep inside
Kat
90 RS 305 TBI A4
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Kat...IM really happy with mine! I had only one problem...The valving was much softer than the stock valving in my IROC box. I didnt like it.. made it too easy to over correct in a corner. The AGR box comes stock with a 210 valve. I sent it back to AGR and had them put in a 220 torsion valve. Its very close to the valving in my stock IROC box now.
BTW...It really tightend up the steering! I bought the 12.1 fixed ratio box.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited September 18, 2000).]
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I baught the Agr box from summit, like MikeH it has a MUCH lighter feeling to it... more like a Caddy than a sports car. But at the time I couldn't take it out to send it back so I just stuck with it. After a few days you get used to it and it makes parking noticably easier. Also plan on getting an alignment b/c your steering wheel will be tilted, in my case to the right about 20 degrees or so, but still a very nice box and I recomend it. Also if you want the heavier feeling to it you can probably buy it right from AGR instead.
'86 TA, T-tops, T-5, 3.73, 4 wheel disks
350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter,
perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable
shocks and struts, Lakewood panhard and trailing arms
14.73 @ 95... traction still a problem
