Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Will AS&M siamesed runners work with SR plenum???
Old Apr 11, 2001 | 09:21 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
It's apparent that AS&M siamesed runners are the best of the aftermarket, but my question is, will they work with the Super ram plenum? It looks like the SR runners are a little different, but it's hard to tell. If they don't work together, then what's better, ported stock plenum and AS&M, or SR plenum and runners. I'm doing research on building a 383, and I think Mini ram isn't an option because of no EGR (you'd think with the cost of that and all the extra's you need, they'd make one with EGR provisions). Thanks
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd B&M Ripper shifter, hopefully I can rob a bank or something and get more
Old Apr 12, 2001 | 07:17 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Nope, totally different plenums between the stock style and the SuperRam. Which would be better is a toss-up, but the stock plenum and AS&M runner combination would be easier to install than the SuperRam plenum and runners.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 12, 2001 | 04:41 PM
Dan87IROC-Z's Avatar
Greg is right the SR Plenum is totally different and the AS&M runners are designed for the stock plenum. The SuperRam is a major pain to install. I have heard it called the "Super Pain in the A$$ Ram".
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Apr 12, 2001 | 09:52 PM
shawn87gta's Avatar
With a little bit of up-front work, I think you can make the Super Ram as easy to install, if not easier, than the LTR set up. If interested, e-mail me and I'll send you a write-up of the installation routine. I spoke with a performance shop owner who verified that this is how he does every one he installs, and it is how I will install mine.
tazs2000
Jul 15, 2017 08:44 AM
MantyZ28
16
Dec 21, 2015 11:02 AM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
mdtoren
Aug 16, 2015 05:45 PM
