Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
SR Torquer 87+ heads and guide plates?
Old Jul 16, 2002 | 08:18 PM
Glen's Avatar
Engine: chevy 383
Transmission: tci streetfighter auto
Axle/Gears: 3.70 moser 9"
Anyone using these heads with hardened pushrods and guide plates? I have some Crane non-self aligning rocker arms for center bolt heads and want to know if I can put the guide plates under the thread in rocker arm studs without having any machining done.
Old Jul 17, 2002 | 05:25 AM
custman87T/A's Avatar
I used hardened pushrods and standard rockers with the heads. Guide plates and self aligning rockers are not needed with the S/R heads.
Old Jul 17, 2002 | 10:09 PM
Glen's Avatar
Engine: chevy 383
Thanks for the reply. I was under the impression that you had two choices. One, use self aligning rockers or two, use non self aligning rockers with guide plates and hardened pushrods. Just checking. These are the 76cc heads for the 350 and are for 1987 and up engines. If you aren't using any guide plates what keeps the rocker on the valve stem? Is the hole through the head casting tight enough to do the job?
Old Jul 18, 2002 | 05:49 AM
The pushrod hole in the head is made for it to be used with nonaligning rockers.
Old Jul 18, 2002 | 09:13 PM
Glen's Avatar
Engine: chevy 383
Thanks! That's good news. Now all I need to buy are some hardened push rods.
evilstuie
Jan 9, 2020 08:29 PM
mhatfield 14
Oct 24, 2015 07:48 AM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
