Dynomax shorty headers?? worth it?
I saw a set for sale for $221.50 it's a set of dynomax shorty headers and a ypipe... anyone had any experience with them?? are they any good?? I wanted long tubes but temporarily I thought these would be nice.. just need some opinions first thanks
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I've been running a set for a few years now. They seem to work fine. I didn't install them myself though. If you have a/c the bracket was modified to fit around #1 exhaust tube, but that might be common to all headers. And I had a hard time putting in the EFE valve on mine long enough to pass smog. But that might be becuase when it was installed I don't think they tried to leave the EFE in place (thankfully). Overall I like them. I haven't had any other headers so I can't compare. Something I have noticed is I like their y-pipe design with how the two pipes come together more than the others I've seen. And it seems to clear everything well. The only thing that was a problem when I first got them is that the collector bolts would break on the passenger side. The headers have nuts welded to them. To fix the problem the exhaust place torched off the nuts and I just used regular bolts and nuts on the pass side and no problems.
HTH,
HTH,
Chad Speier
09-24-2015 12:32 PM
