Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Any good or bad comments on Ed Write Custom Chips?
Old Nov 14, 2000 | 10:41 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Old Nov 14, 2000 | 12:41 PM
BenIroc's Avatar
I hav his custom-chip since two years ago
I`m happy with it.
BenIroc
Old Nov 14, 2000 | 12:49 PM
Garmer's Avatar
He made me one about a month ago, and I am very pleased with it. He has excellent customer serice!
91 RS Camaro
3.1L
Cat Back System, K&N filter,modified air box, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires, soon to come: Homemade Ram Air,and maybe power pulleys, 5 Air Horns
Old Nov 14, 2000 | 01:58 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
What is a number or website where I could get a hold of this Ed White?
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
Old Nov 14, 2000 | 05:10 PM
Rick89IROC's Avatar
www.fastchip.com
Old Nov 14, 2000 | 05:13 PM
bad camaro RS's Avatar
ive got one and very happy with it
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
Old Nov 14, 2000 | 09:59 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
happy with mine
87GTA super-ramed 355, A4 ran high 12's with old school setup and radials, hoping for low 12's or better /91 TA daily driver LB9 A4 2.73,
Old Nov 15, 2000 | 12:58 AM
IROCKZE's Avatar
Car: 85 Mercedes 500SEL
Engine: 5.0 DOHC
Happy with mine...I highly reccomend Ed (unlike TPIS who are dishonest)
85 IROC,5.0 TPI,T-Tops,fully loaded,black with red Lear-Siegler "Camaro" interior,Decal Delete,91 Bose stereo,Stage 2 Fastchip,AFPR,TB Airfoil,K&Ns,March pulleys,Alum. Driveshaft,92 police version 700r4
"The Devil drives a Camaro"
Old Apr 16, 2001 | 11:50 AM
4SPEED's Avatar
CAN SOMEONE GIVE ME A NUMBER OR ADDRESS WHERE TO GET AHOLD OF ED WRIGHT?
Old Apr 16, 2001 | 12:46 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
4Speed, did you even bother clicking on the link to Fastchips posted above? The phone number, address and fax number are ALL there in "Contact Us".
And please don't type in CAPS. IT IS CONSIDERED YELLING!
Old Apr 16, 2001 | 12:56 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Hell with my chip I'm sending it back.
Old Apr 16, 2001 | 08:08 PM
Dan87IROC-Z's Avatar
Mkos, why are you sending yours back? What's wrong with it? Why are you un-happy?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Apr 16, 2001 | 09:30 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
The car seems to have lost alot of power. With the old chip I used to be able to put the gas down and pin myself back into the seat, but with this chip its like driving a yugo. The car screams but doesnt go anywhere. Very disapointed.
Old Apr 17, 2001 | 07:18 AM
Kenn's Avatar
I bought one when I switched to dual exhaust
I'm happy with it
Old Apr 17, 2001 | 08:17 AM
GlennS87's Avatar
Jury is still out on mine. I have extensive mods that really require further tuning. My motor is nowhere near where it should be from a power output standpoint. In their defense, they have offered to modify it once I get them some data from a scanner, wideband O2 and dyno graph.
Their is no substitute for either burning your own prom or at least havin the person burning the prom do it on a dyno.
Just my .02
Neptune, NJ
White '87 Vette - 383 Superram ported and matched to TPIS big mouth intake, Eagle cast crank, 6"eagle forged rods, srp/je forged pistons, LPE 219 cam, ported heads(2"x1.56" ferrea valves), Comp cams pro-magnum 1.6 rr's, double springs, titanium retainers,Hypertech power coil and cap, 4 bolt block, TPIS headers, auto(trans kit,shift kit),Pro Torque 2600 stall converter, k&N filter, 3.07 rear diff., Silver ZR-1 wheels 17x9 and 17X11
Old Apr 17, 2001 | 01:05 PM
IROCKZE's Avatar
Engine: 5.0 DOHC
Remember guys if you have a Stage 2 chip you really need to use premium fuel and a 160 degree stat. If you lost power maybe it's the knock sensor retarding the timing. I emailed Ed about the optimum base timing and he said keep it at spec, the chip will take care of the spark curve.
85 IROC,LB9,t-tops,hard loaded,black with red Lear-Siegler "Camaro" interior,MacEwen white guages,145 speedo,decal delete,91 Bose stereo,stage 2 Fastchip,AFPR,airfoil,K&Ns,March pulleys,alum. driveshaft&spare,92 police version 700r4.
On the list: BW 3.27 posi,89 PBR rear discs,140a police alt,coated TES,glass hood,aluminum front bumper brace
"Use overdrive for high speed pursuit"
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
kah992
Aug 19, 2015 02:55 PM
NWAsonoma
Aug 18, 2015 05:45 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
