This is What i have:
'90 IROC-Z LT1 conversion 5-speed convertable.
What i need are some subframe connectors for this thing. I cannot seem to find ANY for a convertable regardless of year or the conversion to the LT1. Anyone know where they can be found.
Thanks.......
Thanks.......
Remnant, I have a 92 Z28 convertible and I have MAC tublar weld-in sub-frame connecters on mine. Fit is awesome. By the way I have a single cat. In 97 when I bought em they were 99 bucks.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, Fastchips custom chip, 3.23 rear gears, white face gagues, and NOS!
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Chuck Everly:
IRS Terminator Series
http://www.racenet.net/</font>
I'm confused here. Supposedly the "Terminator Series" will not fit convertibles, according to their websites on-line catalog. Last time I had checked on this was that AlstonRacing had a pair that did fit convertibles.
Frobozz,
I have them on my 88 IROC convertible and they fit fine. These are/were made by Alston and sold by IRS.
88 IROC convertible
-=ICON Motorsports=-
88 IROC convertible
i thought convert's came from the factory with sub frame connectors already. that was part of the process of making it a convertable.
Chuck, I just checked out IRS' online catalog and they show four sfc part numbers. Do you know which one would be the correct one for convertibles? Thanks!!
I think you want IRS-18292W. After reading the ad it says it is for 93-98 but I believe that is a typo. I looked up the 93-97 f-bodies and the part number was different.
If it is the same set I have they worked fine in conjunction with the factory connectors.
88blkiroc, You are correct in saying the convertibles came with factory sub-frame connectors but they are not enough in my opinion.
ok, thanks for clearing that up
Alstons clear dual cats on a convertible. I have them on my 89RSconvt and I used to have dual cats.
Very high quality pieces.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Mr. IROC-Z
close
I Use Mac....very nice and nicely priced...$99.00
1990 IROC-Z Conv 5-speed
Mr. IROC-Z
WWW.IROCZDESIGNS.COM Because looks are everything.
Mr. IROC-Z
what are the differences between convert. SFC and regular SFC's?
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
future mods:
Convertibles have two boxed rails under the rockers on both sides that would interfere with stock F-body LCA's. However convertibles and t-top cars respond very well to SFCs.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
